Your flange angles are wrong for both shafts. Should be equal but opposite for OEM shaft and the front diff needs to be perpendicular to the DC shaft. No mans land is hard to fix with a non adjustable front axle housing. Cut and turn, part time kit or some really expensive DC/DC shaft are only options I see...or lower the truck.
I'm gonna go to an alignment shop after work today to get accurate measurements for everything. Hopefully that will help me narrow down where the issue is. Assuming it's an "angle" problem, and not a failing component like the t.case or front differential...
I am still running stock track (panhard) bars front and rear. Using a tape measure, the axles sit roughly 0.5" - 0.75" off center it seems. Could that sideways angle cause the shafts to vibrate and grumble? Initially I didn't think that would be enough to cause the problems, but at this point it seems that's the only thing I have not adjusted for the lift size.
The lateral adjustment shouldn't cause any vibes. More lift means more rotation of the axle housing. Depending on your angles now, lifting would make the issue worse.
After spending more time driving today, the stock shaft really only vibrates noticably around 30 and 60mph. At this point I'm willing to call it a win and ignore it. Seems the caster plates did the trick well enough. Although after spending that much on OEM bushings, I will make the claim I probably have the best driving 80 on Mud.
So now I have a new DC front shaft with about 80 miles on it for no reason... Going to the classifieds soon.
I did a bit more experimenting and confirmed.. adding weight to the rear of my truck diminished the vibes significantly. So I figured for some reason cycling the suspension was causing my angles to go out.
Finally got the rear shaft out to check angles.. .1* difference. Nowhere near enough to cause problems. So I took the shaft to a driveshaft shop..
They immediately noticed that the rear shaft is twisted a few degrees. With weight in back the shaft was lined up more straight so there wasn't as much of the accel/decel of the shaft center and the misalignment between the joints wasn't as pronounced.
The good news is I have a spare one off the body donor rig.. the bad news is I spent $100 in OEM joints for the bad shaft and don't think I can get them out in good enough shape to install on the good shaft.
Anyway.. point is.. as well as checking angles and joints, on a non-DC shaft look down the length and check to see if the joints are exactly lined up. If not you'll have problems.
