I have continuing death wobble with my '74 Fj40. I have been fighting it for some time.
Here are the specs-
4" SUA lift with stock length shackles
new spring bushings within the year
'74 axle with '79 knuckles
Knuckles have been rebuilt, and after the death wobble started preload was increased
New wheel bearings tightened a little above spec (again done twice since death wobble started)
pulled 2.5 deg caster shims in favor of some 6 deg ones.
The death wobble occurs only as I am speeding up/slowing down through the 35-40 mph range. If I can speed up/slow down quick enough it does not occur.
I never had death wobble at any time until the first time i drove the truck with 38's. All the work I list above has been done since then to hopefully correct the problem.
Aside from that specific condition, the handling/ride etc of this rig is better than i would expect with pretty worn 38's. It tracks well, and above 40 mph road irregularities do not induce wobble or shimmy.
Any help is appreciated, as I have pretty much covered the commonly suggested remedies.
Here are the specs-
