Ill runnin 3fe
FLagstaff Az. Elv.7000ft
I just got my cruiser about a month ago and im having problems with it.
the problem is intermittant , first thought it was the fule filter, witch was pretty dirty....so i thought i had it fixed but NO!
Run's fine then starts losing power , like its running out of fule.
when i let off the gas peddle starts to run ok but will only get about 20mphs.....if i stop and let the truck cool down for 30 min's or so it will start and run fine for days....
anyone else with this problem??????????
any ideas....
thanks for any help.
Noobi
Robert
Start with what else, if anything, has been replaced recently (either by you or by the PO). PM is important for these trucks...you have to make sure everything is up to spec, baselined, etc...sounds like you've got off road mods taken care of by seeing your signature...maybe it's time to really dig into that thing and start replacing stuff if it hasn't been done. Start with a coolant flush and fill, spark plugs (maybe cap, wires, etc also), oil change, and check your PCV and other related vacuum items, air filter, the list goes on and on.
There are so many things you might have to check through if it hadn't been done or had been neglected by the previous owner. I'm starting to figure that stuff out with mine that I got about 2 months ago...but slowly working my way through the PM list.
From what I've read on here.. it could be the EFI relay, the wiring to said relay, or possibly the fuel pressure regulator.
EFI relay... i have heard thoes things can go bad and keep the truck from starting,but can they work intermittantly?
Ps..I have done all the PM on this thing as soon as i got it,IE cooling sys,plugs , wires, air filter ect.trans serv, axels...
thanks
Rob
Check your intake hose for cracks.
thanks
Rob
Did you replace the FPR when you did all of the PM? Try that too...might as well get it all.
x 1,000,000
A crack in the intake tube causes a vacuum leak....a nasty one in my case....and will prevent your truck from running correctly for a while.
I always get a kick out of people blaming the EFI relay for everything as soon as they see "3FE". Your truck starts and runs fine but begins to fail after a certain amount of time...correct? If you stop and shutdown it will be fine until a certain amount of time has passed and then the problem of no power repeats...correct?
Fuel pump pre-filter. Change it every 100K miles along with your fan clutch.
Sorry????? FPR, what is that???
fuel pressure regulator. It's an easy change out as it's right on the front/top of the engine.
Did you search for a code?
Not the EFI wire. (Trust Jon on this one)
90% of the time bogging down like you explain = a fuel / air issue. Check hoses and filters like everyone says and don't run low octane gas in the summer on a 3FE in AZ, especially at 7000 feet. Run 2 or 3 bottles of Redline through your tank.
On a 3FE always check the simple things first, most of the time it fixes the ol' tractor.
Don't change your fan clutch, replace the fluid...CSC fellas did mine and wow! got penguins in the truck even during 110 degree days.
That's great that it worked on YOUR truck, but fan clutches can fail in several different ways and they live a hard life. Your fluid is new but the bearing is how old? After 100K miles no parts owe you anything. The fan clutch is prone to failure after 100K miles and it plays too important a role in the cooling system to muck around with. Change them out with new OEM and move on with your life.
I'm with Jon on this one. After chasing numerous leads to curb the detonation on mine after bumping the compression I changed the fan clutch on the first hot day this year because my temp gauge actually moved with the a/c on. After the new clutch ALL of my detonation was gone. Also the fuel pump "sock" will probably get rid of the loss of power.
is there a noise associated with the fan clutch going bad?
:cheers:cliff
Like I said, they can fail in different ways. Always locked, never locked, intermittant, or maybe something in between. It is the single most overlooked item in the cooling system and should be replaced with OEM every 100K miles. People have replaced fluid with varying success, people have come up with ways of testing it that are inconclusive at best (ask me how I know). If you have time and money to waste then by all means play with it all you want. Personally, I like the idea of replacing it with a new one and moving on with my life. One less item to worry about on a 16 year old vehicle.
Update....was the in tank pick up sock, was so dirty i could not see through it when i held it to the sun.......
Thanks for all the help.
Rob
