91 Land Cruiser - Engine Surging
Can anyone help me determine what's going on with my 91 Land Cruiser? I took it to the Toyota dealership and they haven't been able to track it down. I have approximately 300k miles on it. Everything runs fine until I've been running it for an hour or so and the engine will start surging and losing power when under load, i.e. shifting down for passing or going up hill. Once it starts happening, it'll continue when I take it out of gear and put it in neutral until I let off the gas. The last time this happened it was very pronounced I couldn't hold speed at even 20 mph and it started to backfire. It lasted the 5 miles I had to drive to get to a place to stop. Once I stopped it idled fine. Toyota did find a cracked sparkplug, but the surging showed up again today.
SOunds like it could be a fuel filter, fuel pump, or tank screen, With that kind of mileage it could be any of the three. How long since fuel filter change?
Good luck
Dan
91's have an issue with the fuel injection relay and assosiated wiring, maybe you can resaerch if this is your problem.
Replace the pre-filter on the fuel pump. It is made of nylon mesh and once it gets clogged it will start to collapse on itself and block fuel intake. When you let up on it the filter will slowly return to its original shape.
While it is a good idea to replace the inline fuel filter mounted on the right frame rail, a clogged filter would not "be fine for the first hour".
The pre-filter (some call it a fuel sock for unknown reasons) has a 100K mile lifespan.
I haven't been able to get it to do it on test runs. I changed the air filter, checked the air intake tubes (no visable cracks) and found/ replaced a cracked vacuum line by the drivers side fender. Hopefully this was it. My next long trip will tell.
I would expect that because you said it runs well for the first hour or so. As the fuel in the tank warms up, the pre-filter becomes more plyable and collapses on itself.
I repeat myself only because I have been down this road before. Bad gas, bad plugs, bad wires, bad coil, bad fuel filter, bad wiper fluid, bad tires, etc. will (99%) not show as intermittants.
The majority of Toyota "specialists" don't know this pre-filter exists. I didn't know about it until I was ready to replace my fuel pump simply because I had replaced everything else to try to cure the same issue you have.
There is a thread on this somewhere...
https://forum.ih8mud.com/showthread.php?t=66380
Thanks for the help. I installed the prefilter (thanks C-dan) in less than an hour and I took it for a 2 hour test drive towing a trailer and it never came close to having the problem. I was suprised how easy Toyota made it to get to the fuel pump.
