Ignition switch help
Seattle, WA
Ok, I am trying to get rid of some Great PO wiring jobs and trying return the wire harness to stock configuration. In the toyota wire schematic it shows the ignition switch with posts labled ST, ACC, IGN, AM. The ignition switch in my cruiser has posts labled ST,ACC, IGN ,BATT. I was wondering if the AM=BATT. I know it might seem obvious by process of elimination, but I just want to make sure. I dont want to burn up the wires if I dont have too.:o
Thanks, here is a piece of the amp meter wire I replaced today(connected to fuse block). The end with the terminal connector is all burnt and you can see bare wire, as well as another bare wire spot on it. The PO just wrapped it in electrical tape and called it good.:rolleyes: I wonder why it got fried?
No doubt that it shorted to ground somewhere. This wire (white/blue stripe) is the most potentially dangerous wire in the entire chassis. It carries the entire chassis power from the battery and alternator to the fues block and ignition switch. The battery lead has a fusible link, which should burn out before the wire, but the wire from the alternator (also white w/blue stripe) is not fused, which means that it will continue to fry if the engine is running. Make sure that this wire is in good shape and is not rubbing or wearing against any grounded object.
Hmm, the wire that runs from the battery to the meter doesnt have a fusible link on it. It also doesnt show one on the schematic. What amp rated fuse would you suggest for putting one inline on this wire? Thanks.
Red; just curious, what schematic are u using to rewire said FJ40? Be nice if we were on the same page. I would be using a 1978 or 1975 schematic be cause they are readable, compared to the pre 1974 versions.
Although I have not put an inline battery fuse in my FJ40, I would use a 100a fuse. That will more than handle current/future loads, yet still blow in the event of a short on that line.
I am using a 69-74 FJ40 Toyota FSM. I have the actual book, not what is posted online. I can read the schematic pretty good. The problem with the later(75 or78) schematics is that they are not similar to my 65s wiring.
Well crap, I got rid of some stupid toggle switch that the PO had put in, it cut the ciruit between the battery and the amp meter. I wired it all back together like the schematic says and my cruiser still wont shut off when I turn off the ignition. I can even take the key out and it just keeps on running. I am soooo confused. I have no idea as to how the coil is still getting power. Any ideas how this could be happening? It doesnt matter if I even switch in another ignition switch.:mad:
Sounds like your old friend PO hot wired the ignition after the toggle switch you removed and before the OEM ignition switch. Maybe he did it because the ignition side of the switch is shot. Follow the wire back from the coil or ignition switch to find this jewel. Look for any solid color wire, since most of the OEM wires are striped.
Thanks, I will check it out in the morning and report back. One question, does the wire that comes from the alt(white w/blue stripe) connect directly to the ingition switch at some point? Mine currently splits and one goes to the meter and the other goes to the fuse block. Then a wire from the fuse block(same side as where the amp wire connects) to the ignition switch. Is this wrong? Thanks for the help, I really appreciate it.:)
Chase, as PinHead alluded to, that wire IS the main artery so to speak, for the whole truck, and SHOULD be fitted with a fusible link. Unfortunately, Toyota did not start installing one from the factory until 74 IIRC. You can and really should consider retrofitting your harness with one RIGHT NOW, while you still have a usable harness to attach it to. :doh:
You can buy generic aftermarket fusible link wire at most auto parts stores.
Strange flight of thought here. You do know that the fuse block is separated into two parts, constant hot and keyed hot? You might want to make sure that the wire going to your coil is on the keyed hot half of the fuse block, rather than assuming that it is.
Mark,
yeah, I will wire one up tomorrow. You are talking about the wire from the battery right? not the one from the alt. The wire that runs from the coil goes straight to the ignition switch. Then a wire from there supplys power to the hot keyed part of the fuse block. Thanks for the help.:cheers:
I GOT IT!!!!!
So I traced the coil wire back to the ignition switch and it was uncut or melted. I noticed that there was power going to the ignition switch post. So then I went to the fuse block. The wire that sends power to the hot keyed part of the fuse block was getting power. So then I figured out that a wire on the fuse block was sending power reverse through the block and to the ignition wire. I found that wire that was supplying the power and it turned out to be the brake light switch wire. I follow that wire and found that it was connected to a wire that was getting power from the constantly hot part of the fuse block. So the brake switch was getting power from two sources and constantly keeping the coil hot. wew, that was a lot of writting. I am now going to take it out for a test drive. Thanks for all the help guys. I will get that 100amp fusable link today. :beer:
For those of us who still have our early wiring harnesses intact,
where should the fusible link go? What amperage? I don't
really like cutting into my stock harness but in this case it sounds
like a really good cause. My cruiser is a '68.
RGENTRY;
Here is some good info on wiring, etc. FJ40's are wired a lot like old chevys.
http://www.madelectrical.com/electricaltech/chevymain1.shtml
The pictures show where the "fuse link" goes. A fuse link is a smaller diameter piece of wire than the rest of wiring harness. For the FJ40 a piece of wire about 6 inches long, 14 gauge will work. It is a weak link in the electrics and will take a lot of abuse, but will burn up first in case of a short in the harness.
I'm always amazed at the amount of verbiage on the madelectric site. Most of it is just harmless hyperbole, like the claim that there is something unusual or clever about the design of the charging system of older GM cars. It's an entertaining story, but COME AWN.
A simpler interpretation is that GM used the smallest wire consistent with safety and the shortest length dictated by the location of components to minimize their manufacturing costs. They didn't worry about any potential voltage drop of 0.5V at maximum alternator output because it is insignificant compared to the cost of running larger and longer wires.
