If your horn doesn't work
Romer
fatherofdaughterofromer
Moderator
Centennial, Colorado
My horn became intermittant and finally failed a few days ago. I took off the steering wheel and verified that the button worked and the relay worked. Turns out the copper disk that goes against the contact for the relay had worn through. Just thought I would post it in case anyone else is having a similar problem
I went in the garage to think about it and decided to take the angled contact out of its set pin and move it slightly so it contacts an area that still has the copper and it now works. Tighten the screw down real tight to keep it in place. I also put a dab of silicone at the set pin and bracket to keep it from moving.
Then I would be driving like Ige . . . . . Ige is my Hero!
Try and share a bit of tech and look what happens. Pretty soon Poser will come on and say Chat Chat. Steve, it's not my fault.
Romer
Based on this experience, do you think the copper disc could be cleaned without removing the steering wheel? I'm not getting a good contact and thought I'd ask before I yanked the wheel.
Thanks
Peter
There is not really any way to gain access to that contact plate to clean it without removing the steering wheel from the column.
FWIW, that does not look like any factory steering wheel from a 40 series…This may have been from one of his newer Toyotas.
Hey, cool. Just yesterday noticed my horn isn't working as well as one might hope. I'll have to yank the wheel and see if this fix will work.
Thanks Romer!
