Identify a Transmission
Lockhart
Hello all, looking for a little help identifying my transmission. I have a '80 Fj43 from South America with a 5 speed transmission. Are there any marks that note what I have down there?
pics would help in this situation
10/82 is when the Toyota H55F five speed started. 40 series have a different top plate then other series that had the H55F. Besides pictures from below a picture of the shift cane would help determine which H55F if that is the five speed you have. 80 model is too early to be a.factory installed transmission five speed. The non 40 series is more commonly used H55F if not a factory install.
I know it is not the factory transmission sold with the truck
The trans mount is missing, it looks like its suspended from the bellhousing like earlier model 3 and 4 speeds. The bellhousing does look like it is mounted to the frame. IMHO if the crossmember is there (which it is) then run the trans mount.
Dyno
Dyno
Can you elaborate a little on what I need here? Where would the trans mount go? Would it be an h55f trans mount?
This transmission was from either a 60 series or 70 series. The transmission shift cane and transfer case shift lever are further back then what was used on the 40 series. You can see the transmission shift cane is bend almost straight up. On the 40 the five speed cane were in the same location as the four speed. Transfer shift lever was a little further back but not as far as your.
The 8/80 transmissions in the 40 series used a three piece crossmember setup that supported the transmission from the bottom. The main crossmember section bolted to two L brackets that bolted to the side frame rails. Supporting the larger five speed transmission and transfer case is of the opinion too heavy for the bellhousing mounts. Going with the crossmembee setup when I install a five speed in my 79 FJ40. Also going to run a PTO that adds even more weight.
See pic
yes a H55 or an H42 mount should work fine get one for a pre 84 as the angle changed on the 4/85 and later mount.
Dyno
1899168
See pic
DynoView attachment 1899168
The date change of 4/85 is mainly the US market 60 series. Most markets the change was 11/84 for the 60 and 70 series with a H55F. The 4/85 from what I can tell was the date the market still getting a four speed add the spacer to the back and rotated the transmission to standardized everything between the four and five speed. Crossmembers from the 60 and 70 series will require some modifications to work. L brackets from a short and mid wheel base 4X series will work. 10/82+ from any 4X series were made for the five speed. Has better clearance for the front driveshaft which the T case flange is further back with the five speed. This is something to think about with a lift that will increase the angle of driveshafts.
Thanks for the advice all! Now the search begins for a trans mount. Anyone selling?
Yes, anybody sells it. A transmission mount for 81-84 FJ40.
He needs more than the isolator pad. He needs the whole crossmember. Believe other than the isolator you either need to fab one, buy a aftermarket or used one. Easiest would be used from a short or mid wheel base 4X series 10/82+. Those would only require dealing with bolting the L brackets to the frame rail that does not have the fixed nuts. Because the number of 10/82+ 83 models imported to the US was in the low hundreds something from another market is most likely best option. My two 10/82+ crossmembers came from a BJ and HJ from the Australian market.
Problem resolved. I do have the crossmember and I found the mount on Ebay. Thanks everyone for walking me through this! Im new to these cruisers so I do appreciate the guidance.
if using the crossmember setup, you should remove the existing bellhousing mounts.
it should be 1 way or the other but not both.
I'm getting many mixed responses here. Does anyone have first hand experience with this trans set up?
  1. Do I need a transmission mount?
  2. Is the bell housing mount in any way inferior to a transmission mount?
  3. If the bell housing mount is sufficient why recommend a trans mount?
