Identify a Transmission
It would appear your hi / low selector isn't attached.
I'm getting many mixed responses here. Does anyone have first hand experience with this trans set up?
  1. Do I need a transmission mount?
  2. Is the bell housing mount in any way inferior to a transmission mount?
  3. If the bell housing mount is sufficient why recommend a trans mount?
you need some sort of rear mount either on the bellhousing or the transmision.
the bellhousing mounts were used from the mid 60's? up until the 1981 model year, 08/1980?
the transmision mount was used from 08/1980 until the end of production
with just the bellhousing mounts and a 5 speed the entir weight of the transmision and transfer case are being supported by 4 bolts into the back of the bellhousing
the 5 speed is several inches longer than a 4 speed and weighs a little more
using the transmision mount it supports the transmision directly
Good eye, I wonder what happened there.
