ID my Birfield.
It might be better to post some dimensional measurements, mainly the length of the shaft from the joint to the splined end.
For a knuckle rebuild, whether your birfield is LC or Minitruck is not relevant.
Here is some pics. Thanks.
Doing a Knuckle rebuild on my 1978 FJ40.
The I.D. on the Birfield NTN 100AC T G 4.
Is this a Mini Birfield or a 40?
Thanks,
Paul
if it is stock, 78 would be the long birf, 40 or 55 series 76-78 only.
if it has been swapped out to the later style, short birf, 79-90, it doesn't matter if it is a 40,55,60 or 62 series as they are all the same birf.
Running Warn hubs, would to run new Aisin. Not sure these are stock or not. First time doing a knuckle rebuild. Sent some pics and measurement to Kurt@ Cruiser Outfitters, awaiting his comments.
Looks like a 40 series. The flat spot is a lot bigger on a 40 series than on the others. That is why you have to grind out the housing to get the larger one in. The flats are smaller on the later ones. Easy way to tell.
Looks like a 40 series. The flat spot is a lot bigger on a 40 series than on the others. That is why you have to grind out the housing to get the larger on in. The flats are smaller on the later ones. Easy way to tell.
HUH? there isn't a 40 specific birf. all 79+ birfs have a larger bell that is why the older axle needs grinding inside the axle ball to clear the larger birf.
all 79+ birfs are the same whether it is from a 79-90, 40, 45, 55, 60, 62, 70 series or solid axle mini truck 79-85
Looking at the two birfs in the post above #10, one can see the flats on the one on the right is larger than the one on the left. With it being longer as well , it tells me it is a 76-78 40 series birf.
Yes from 79 up they are the same till you get to the 80 series.
By flats I mean where the Longfield logo is. The flat part of the round bell.
Sorry for any confusion
