I blew a seal
Hanford, Ca
Website
instagram.com
No I'm not talking about a singer, or a seafaring mammal. I've been smelling something nasty the past couple of days and this afternoon when I pulled into the driveway I saw smoke coming from my driver's side wheel. So I did some looking and it's pretty ugly. See photos:
It's pretty bad. I don't have time to fix it until 4th of July. And no money till then either. Think it'll be safe for my 6 mile round trip commute until then? What kit should I use? I was also thinking about the upgrading the brakes and rotors while I'm there. Any one have any suggestions on what to use, stock rotors and 100 series pads, or go aftermarket? I plan to just follow the write up in the FAQ and the FSM to do all the work.
I like the toyota inner axle seals better then the marlin seals. But you can get the rest of the rebuild kit from marlin crawler. I like my 100 series pads and power slot rotors.
Did you check the fluid level in your diff and the grease level in your knuckle?
I would guess that you can top off each and just keep an eye on them for the next two weeks. That's my opinion.
^^^^^^Same as LS1FJ40 said^^^^^^^^
Just a another tip...
If you end up replacing your inner axle seals, check for grooves on the axle shafts. If you have grooves, reposition the seal not as far in so you get a good sealing surface.
Drive it you'll be good for a loong time.
I'd pull the diff breather tube at axle just to be sure that it is not plugged and clean the tube. If this is plugged you know why she puked.
You definitely have birf soup going on.
Check your axle breather hoses and fittings for blockage. That can be free, just by removing the hose, clearing the hose and fittings and reinstalling.
Do as @LS1FJ40 stated.
I got my kit from Kurt at Cruiseroutfitters.com. I also did all the bearings. Everything EXCEPT removing the differential and rebuilding that. I bought Power Stop rotors and power Stop pads (100's in front, 80's in rear) from Summit Racing. They were the lowest cost at the time. I'm happy with them at this point. Also buy new spindle lock nuts and the star washer OR go to the alternative setup from ????Can't think of it right now. (do a search for spindle nuts and you'll find it.) CDan for axle seals. If you need Birfields,I bought the RCV stock version through Slee.
May want to consider the soft brake lines as well. I replaced mine with Slee SS extended lines because I am planning a lift in the future. Make sure to consider replacing the soft lines with at least standard due to age and brittleness.
Stock up on nitrile gloves and paper towels and brake cleaner to make it all happen. If you don't already own the HF seal/bearing race driving kit, get one. Well worth the $35.
Wheel bearing grease: Lucas Red-N-Tacky #2 (4 tubes), Valvoline Palladium Moly Grease for Knuckles (4) tubes, 85W-90 gear Oil for diff. Loctite Red and Loctite blue for various studs/nuts, and the 54MM socket.
You didn't use Kurt's Axle Seals? I'm looking at this Brake Kit for the replacement. I've ordered stuff from Kurt in the past and was pleased with shipping times and product so I'll probably go that route as well. Plus he's super easy to get a hold of. I also only live 40 miles from Marlin Crawler so I could just drive up there. I also have a $25 gift certificate from my birthday last year that I still need to use. So I may go that route too. And someone remind me why we don't use the Marlin seals. I know I've read it before but I can't remember what's wrong with them.
X4 or 5 on the diff breather. You may not have a bad seal. Your breather could just be clogged. My seals were in great shape but I had gotten some birf soup. I replaced/extended my diff breather up in to the engine compartment and drained the diff. That was about 7-8 weeks ago and I checked my birf yesterday, diff fluid was clean as a whistle.
Checking the Diff breather now.
After the hours and hours of reading before I bought all my parts and comparing costs of 5 or 6 vendors, I chose Kurt's kit and stuck with the Toyota axle seals due to them being internal and a difficult and expensive task to get to if they needed replacement. I forget the difference in cost, but when I look at "critical parts", I usually don't worry about who's least expensive. It's more about which one will last the longest. I'm sure Kurt has good stuff, I just wanted to go with tried and true.
In case you need the kit and prefer genuine Toyota parts, I carry the Genuine Toyota sealed kit with 43% off. ;)
Looks like you blew a seal ;)
I'll be the first to admit i am new to these trucks, but It seems like most cruisers i look at the leaking from the front axle looks like the one in the photos. Since you guys feel that the leaking in these photos is a problem, could someone please post some photos of what is considered the normal amount of lube that should be seen on the front axle.
Here's my other side. It's just covered in road crap and mud. See how there's no soup on the big shiny ball? That's what you want. It's bad when it has that grey soupy mix because it means there is gear oil mixing with the grease in the knuckle and those two things don't exactly work well together. It's also bad if you drain your diff oil and get a grey soup draining out from there.
To answer your question more directly the normal amount is none. Things with seals normally shouldn't leak.
So I checked the breather. Seems to work fine to me. I can blow air through it with just minimal resistance. Since I had it out I went ahead and moved it up to the engine bay cause why not. It's dark out right now, but I'll take a pic tomorrow and show you where I put it.
Just did a full seal kit from Marlin. Since I tore mine all the way down to bare housing to do it, checked locker, ring n pinion wear and play, serviced the whole diff essentially. Hearing all the mixed opinions, and knowing the internals pretty well to where I could do an inner seal in about an hour, I decided to give Marlin a run for his money and put a stock dealer inner axle seal in the passenger side and a Marlin Ecoseal in the driver side and I'm gonna see firsthand which one let's go first. I also installed a set of RCV chromo inner and outer so the position won't be an issue. I've noticed over the years than when installing the axles back into the housing, some people don't lube the inner seal, but most importantly, almost everyone installs the axle assembly and doesn't clock it for a direct fit (all the way in, first try) so they have to stop and rotate the axle shafts to get it in. When they do this, they let go of the axle, letting it rest so to speak, which stretches the seal from day one. My advice, carefully support the axle through the entire installation process, from splines to seated. If you do need to stop and clock it for the birf to get into the bell, carefully support the weight of the axle when you do so, as to not let the weight of said axle assembly rest on that inner seal, distorting it's sealing surface. This is one of those meticulous items I'm up tight about, after seeing many seals fail from day one. If you have the time, pull the whole diff and clean it up, and a fresh coat of paint. :cheers:
