guys, i am want to drop a diesel in my LV i have a lead on both a hz and a hd-t. i am putting a h55f behind what ever goes in any advice as to what to look for would be great.
BEB problems? i am new to deisel's.
thanks for the heads up anything else i need to be aware of? i think that both of these should be able to mate with a h55 right?
That's funny Mot, we both posted at the same time with the same info! Jinx!
Get the engine which is within your budget. HZ conversion to HD-T (12 valve, 1990-1995) can almost be done in one weekend. I would try to source a 300 mm flywheel and use it on either application with a H55 behind it (using the Isuzu NPR disk w/ Toyota HD-T PP).
As I have posted in the past, the starter motor in a HZ/HDT in a left hand truck is very close to a tradition 40 series steering box and you might want a saginaw or 60 series box conversion to eliminate that problem.
Not being familiar with diesels understand that you have a vacuum system to set up, as well as wiring, air cleaner, power steering cooler/hp line etc. I'd look over an install of a HZ or HDT before you jump in.
great engine, great power.....
I already changed the steering, and was aware of vaccum system, air cleaner, and other periferial system changes. i just wasn't sure about the motor/trans bits.
thanks for the help.
so besides the turbo what is the difference between the hz and hd? i am guessing it is in the head? 24valve vs. 12 valve?
HDT pumps and injectors can be rebuilt here in the US cheap (I had my pump overhauled for about $600 and injectors serviced w/ one new tip for $100)
so it sounds like my best bet as far as parts go would be a 12 valve hz? and these can be turboed , does adding a turbo required the 24 valve head for the best results?
there is any place in NA that can rebuild the both 1HD-T injector stages .. ?
