- Joined
- Sep 28, 2002
- Threads
- 558
- Messages
- 8,124
- Location
- Kamloops, BC Canada
- Website
- www.shopraddcruisers.ca
|Once together and everything hooked up, if the steering wheel resists turning right and will go left on its own, valve problemin the pump??
possible reversed lines, but my guess is you are testing with the drag removed...should only move at full lock if it's disconnected...
also possible there is air in the system....if you are SURE the lines are correct, hook the drag back up, get the axle on jackstands, and go lock to lock with the motor OFF.
Came home from work the next day and miraculously everything worked just as it should.
i love when that happens![]()
