Hump
Reno, NV
Website
forum.ih8mud.com
I'm in the final stretch of some minor renovations to my rig.
One of the last details I need to work out is re-fitting the tranny hump. With the addition of a ToyBox and AA propeller support it no longer fits.
I've already beat the bejezbus out of it and made a couple of relief cuts. Still not making it. At this point I'm ready to just hack the back end off and weld a box of 18gauge sheet metal over everything. With my mad fab/welding skillz this should turn out about as attractive as a mud fence.
Any other suggestions?
I had to modify mine to work with the 420 and Atlas...but I wanted a flat bottom....
It is really not that big of a deal.....cut some pieces....weld some things together, and be done with it.
Who is going to see it? ;)
Further, why does their opinion matter? ;)
Good luck!
-Steve
Good luck!
-Steve
x2
words from the master
Can you make a cut and extend it with a patch panel to get the clearance you need. I gotta think fabbing one from scratch would be even more of a hassle.
just .02
Rezarf <><
Guess I break out the angle grinder and cutting wheels. I picked up some .023 wire and tips, along with a sheet of 18Guage steel.
I'll take a few picks and if the result aren't to embarrassing I'll post them up. :o
While you're at it, you don't really need all that hump space next to the gas pedal for ANYTHING, so you might as well reconfigure the front of the hump to add a couple inches more room for your foot.;)
That is actually a great piece of advice..
It never occured to me and sine one day I will actually have to make a new tunnel cover I think I'll keep that nugget of info handy :)
thanks Mark ;)
thanks Mark ;)
In the department of giving credit where credit is due, that tidbit was passed along to me by Jim Sickles last year. He in turn got it from Jonathan Ward when he was complaining to JW about lack of foot room in his 45.
I spoke with Ray, TLC's service manager about this on Saturday at the TORC show and he said they've done a 'few' of them.
Since I've got an extra tranny cover for my 45, I'm planning on exploring this on my own rig when I do my 4 speed conversion.;)
I'm in the last stages of building a new hump out of checker plate. Talk about a jig saw puzzle.
Hurmmmm, maybe I'll try to find some more 18guage.
Make radial cuts toward the higher parts from the edge without cutting the resulting pie shapes completely out. Then spread the triangles as needed to clear whatever is hitting underneath. Then cut triangular pieces to weld into your triangular openings.
I know my description is crap and it's hard to see what I mean but think of one of those wire or hose grommets that have cuts around the opening to make the rubber spread only enough to pass what you put through. Or spread your fingertips on a flat surface and see the triangular openings between them (unless you have only just begun the immense journey).
Was trying to figure out how to say that, and have it understandable. That is exactly what I have done when modifying tunnels, and other goodies.
:beer:
