Hub/rotor attachment?
Metro NY
I just disassembled 2 hub/rotor combos and they were different than I expected. My fading memory recalls that hubs wheel studs get pressed through the rotors from the back and into the hubs. The ones I just took apart - that I THINK were from an FJ40 - have the wheel studs in the hubs but they were not through the rotors. The rotors were held to the hubs with 6 bolts from the back.
Am I nuts? What are these from?
I guess this is right for the FJ40... my memory is from FJ60 style I guess.
So... are the 40 and 60 style combos interchangeable? It seems they would be...
40 followed by 60:
"bolt" is the wheel studs. FJ40 rotor has 6 holes for the little bolts to hold the 2 together. FJ60 rotor has 8 holes, 6 for wheel studs, 2 for little locating/hold together bolts.
Of course yer nuts! That goes without saying...
Those in the pic are FJ40. Your memory is of how FJ60 hubs are assembled.
Nick
So are they interchangeable? (the matched pairs that is...)
Is the 60 style an "upgrade" for a 40?
I "upgraded" my 40 to 60 knuckles and in the process I used 60 hubs etc. I bought OEM 60 rotors and associated bits... I never looked at the 40 stuff I pulled off until now.
Thanks for the info all...
Change in the wheel bearing hubs/rotors was 08/80.
Later had the two bolts and six wheel studs retaining the rotor to the wheel bearing hub.
07/80 and earlier had six bolts retaining the rotor to the wheel bearing hub only.
The earlier assembly and later assembly interchange, meaning, you can use the "six bolt wheel bearing hub and rotor assembly" on a 08/80 and later 40/60/62.
:meh:
:meh:
And vice versa?
:meh:
Because the spindles are all the same for all disc brake 40 series and 60 series front ends, right?
Do you need to change backing plates to have the calipers line up correctly?
Just for completeness sake, minitruck hubs are also compatible and there are two types.
i don't know what date they switched over, but the earlier hubs go with the 6 hole rotors while later hubs go with 8 hole rotors.
The "backing plate" has no effect on caliper/rotor alignment. The caliper attaches to the mounting eats on the knuckles, not the backing plate.
Yes the spindles are the same from all disc brake 40/55/60/62 series
woytovich said:
So the opposite of the Land Cruiser switchover? Does that mean that the later 8 hole mini rotors will fit on the earlier FJ40 hubs properly? (It was said that the early rotors for the 40 were harder to get - is this the same for the later mini rotors? Do they need to come from Toyota?)
No mark, the changeover occurred at the same time, 08/80.
Early rotors are used with early hubs only
Later rotors are used with later hubs only
This is not that complicated
No, not backwards. As with the 40/60, the early hubs are 6 hole and the later ones are 8 hole.
I know this only because I did a minitruck disk swap and got the large pattern steering arms but the 6 hole hubs.
There are ways to use 8 hole rotors on 6 hole hubs if you research here, but the simplest is just to find the newer hubs.
Early (FJ40) HUBS have 12 holes (6 for wheel studs and 6 for smaller bolts) and ROTORS have 6 holes (for the smaller bolts)
Late (FJ60 and late FJ40) HUBS and ROTORS both have 8 holes (6 for wheel studs and 2 for smaller bolts)
In both cases the smaller bolts hold the rotor to the hub.
In the case of the early ones they are the only connection between the 2 and the wheel studs go only through the hub.
In the later case the 2 bolts hold the rotor and hub together AND the wheel studs get slipped through the rotor and pressed into the hub, also holding the 2 together.
You can skip the 2 bolts in the later arrangement but they are required in the early arrangement.
For the 40's that take the 6 hole. I just got some in from Parts Geek. Mountain Brand made in Japan. About $138.00 for the pair.,,Jeff
