So about 3 years ago I picked up a 91 80 series with the 3fe. I've always loved these land cruisers but never had one till then. It gave me tons of problems with not starting right and I knew nothing about the different engines or locker options. I been searching ever since to get a 93+ with factory lockers. Long story short I never wanted to pay up for one. So last week I bought a 94 that needs a head gasket. I always loved working on toyotas but never dealt with a timing chain or inline6. I searched everywhere for the dvd that is talked about "Doug from Idaho"? I couldn't find it. I lost patience and started tearing down the engine. Only having a couple hours after work to do it I'm stuck on how to take off the timing chain. Any secrets before I break something? The rest seems fairly self explanatory. Is there a tensioner like belts have? Any advice would be amazing!
Also how do you tell if the head is warped and if I need it machined?
My plan is so far I ordered
Head gasket kit (oem Toyota)
Aisin water pump
Ngk wire set
Denso iridium plugs
Snorkel
Thermostat
Phh
Any other things I should consider? Truck has 177k miles. Very dirty engine. Assuming leaky valve cover can make things VERY ugly.
Thank you!
Also any cleaning advice?
Aisin water pump
Ngk wire set
Denso iridium plugs
Snorkel
Thermostat
Phh
Thank you!
