bamabrock said:If it has nipples, can you milk it?
99% of people wouldn't know it wasn't factory. I'm going to leave the parking light covers on mine though.
bamabrock said:Have you figured out the adjustment? I'm going to attempt mine this weekend when I get home.
bamabrock said:it looks like the top might be hitting, and if so, that would cause them to aim low when you tightened to back locknut. A little trim of the shroud with a dremel should fix it if that's the case. I'm going to mount the projector without the shroud, get it finetuned in the garage, then make the shroud fit before I reseal them. Nice to be able to learn from others' experience, so thanks for being the guinea pig for us![]()
Did you take pics of the area you cut on the housing?
what about wiring? it is plug and play, or since you already had the DDM kit in you already had the wiring complete.
Thanks again
