RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
I have had no issues thus far been sevral hundreds of gallonsAny issues running these pumps on the factory wiring?
I was told they have a 7v resistor
Where are you guys getting the Denso Fuel Pump? Just doing a price comparison before I jump in on one from Toyota.
https://www.amazon.com/Denso-950-0109-Fuel-Pump/dp/B000C5SIU2/?tag=ihco-20 This is the OEM equivalent.
Supra ebay >> Fuel Pump Mounting Kit DENSO 950-0155 fits 93-98 Toyota Supra 3.0L-L6 | eBay
Supra amazon >> https://www.amazon.com/Denso-950-0155-Fuel-Pump/dp/B000C5WFOC/?tag=ihco-20
Yes I did. Found what looks to be the same one in the amazon link from @4G63 POWERCheck Rock Auto??
Great write up thank you. From what I can figure out you should use Teflon/PTFE insulated wire rather than the regular silicon or pvc insulated wire because the corrosive effects of the gasoline.Here is where you start to question your own wiring skills. How in the hell is electricity powering the pump THRU gasoline and NOT exploding?!??! I digress.
I had to make new ring terminals with a length of 14 awg wire. I could have drilled out the rivets and made it one continuous run (what I normally would do) but instead I decided to extend the wires from the connector. A couple butt connectors later and I was ready to rock.
