It's the rotating preload you want to measure. You are good there you will likely be under preload even if you add.003 there.
Thanks for the feedback but something is jacked up still. The crushsleeve was at 27 lbs on the torque when I first did it. Today, 2 weeks later, it showed 15, video. So I was being lazy and just figured it was good as opposed to disassembly and using a solid sleeve I bought.
So with that crushsleeve I get the ring gear back in, backlash, etc. Re-Test the preload and it’s 30. I know that is too high even when ring gear is in. So I take the ring gear out and re-test the pinion and the preload is back at 27lbs, just as is was 2 weeks back when I thought I over crushed.
After cleaning up a bit and using my hand to turn the pinion gear a few times the preload loosened up again to 15.
I can’t figure that out so I just disassembled the pinion and will use the solid sleeve. Try it again next week.
I’m not to sure how this solid spacers works with shims. I assume I put the solid sleeve in, use shims if needed, and as long as I torque the pinion nut to the spec and achieve the right preload I’m
good...from first look, holding the smashed crush sleeve next to the spacer, they look like the same height. I might just try with 1 or 2 shims.
