Like an Aussie locker or a selectable? If it's an auto locker then it's not difficult. Hardest part is removing the 3rd and putting it back in. If you have the correct parts in the box and don't tear the diff gasket then you are looking at about 3 hrs of work.
The last locker installation I did was a Ford 9" with a Detroit locker. If you are just installing the locker without re-gearing, it is a fairly straight forward job - once you have the right tools (dial indicator for sure) and spare parts (bearings, shims, etc). Most important is PATIENCE because it will be surely tested a few times. Directions on gear mesh patterns are readily available on the web so you know where to add or subtract shims.
But definitely doable by someone who is willing to try it.
I did all my backlash settings by feel and I just opened them up to service the ARB air collar O-rings and the gears were totally fine thats 10,000 rough miles later so take it for what its worth. Original paint was showing a close to stock wear pattern. That said, if my trail rig was a DD then I would have definitely used a dial gauge.
You do need to be aware that the 3rd member is heavy AF (seemed like all of 75lbs), find someone with a lift because you don't want to do this on your back.
copy all that.... It would be an Aussie locker..... i'll check if there is a fellow mudder in San Diego that wants
to hold my hand during the process, daily driver toting 3 kids to and from school. i'll need it operating
correctly in short order. Thanks guys
There are a lot of places that will install an auto locker or regear for around $250 (PM if you are in socal and i can refer a few places) if you bring them the 3rd member. What's nice about our trucks is that you can take the third somewhere and have it setup, then just drop it back in the truck. Unless you plan on doing this often, the 250 seems worth letting someone with experience and the right setup take care of the precision stuff. Just my 2nd cents.
Aussie locker is childs play... OK maybe I'm oversimplifying it, but it's really not that bad. About 4 hours with zero experience, about 2 hours the second time you do it Unless you forget to read the directions because you've done it already
:edit: and I second smokingrocks. Get some 90w gear oil to fill 'er back up. It will run fine on regular gear oil, but the heavier oil is quieter and reduces some of the lunchbox locker idiosyncrasies.
:edit: :edit: there is nothing "precision" about installing a lunchbox locker. No adjusting backlash, no precision measurements or looking at gear patterns. Basically if it fits together and works, then you did it right
I suppose you could use a factory gasket in the rear third.
Or your could use silicone that will bond better with less chance for leaking.
This is more apparent on the front. When I pulled my front axle, sections of the gasket had been pushed out the third member seal and were completely missing in a couple other spots.
I use RTV for all connections where paper or cork gaskets were in use before and I never have an issue. I would suggest an even higher weight oil we are running an 85-140 on a rear Aussie locker for my friends mini truck and it helped far more than 75-90.
Very nice must have option, now stuck with rear wheels of the ground so get a hi-lift and winch: only true stepping stone theory
The POSi comes with new shaft and even a little wear on that is bad so new is very important, and no need for spacer rings
in my hj60 I used the old parts.
Installation in this topic, dont read how I messed up measuring the spacer ring/shims, what a pain, anything below 1 mm is hocuspocus to me, if my eye cant see any difference it is a headache
My son and I installed my Aussie locker with limited tools and experience. However, we did encounter an issue that was mentioned by other Mudders - the original side thrust washers were too thick. Instead of waiting at least five days to get replacement washers from Japan, a buddy and I faced them on a metal lathe. Also, go ahead and plan on replacing the axle shaft, and 3rd member gaskets.
The process is straight forward and with the use of a good quality digital camera or a phone, you'll have no troubles. In addition to the great suggestions mentioned previously, one thing I suggest is measuring your ring gear lash (or play) before you start so that you can put it back to what it was (or a little tighter if it was sloppy). also, take several pics from different angles of your teeth mesh pattern so that you can put it back exactly the same way. If the mesh pattern wasn't perfect, don't change it. Put it back the same way or you'll hear whining from the new pattern! Zuk is a good resource online as he has tons of mesh pattern pics.
Ditto on replacing the paper gaskets with new ones from Toyota. Toyota makes good quality machined mating surfaces and RTV is not necessary. Now, if this was a LR, that's a whole another story!
