How could this happen.
OMG, I have NEVER seen a steering box mounted like that!!!!
If anything could be worse than stock, that is it.
That is one funky looking steering setup. Your pitman arm is stripped, and possibly your sector shaft is stripped as well. If you drive it like that, most likely it will be your last drive on earth. Don't drive it until you get if fixed. I would put a stock steering box on with power steering and get rid of that funky steering box altogether.
Wow. That is some cobbled together steering.... the fact that it simply now doesn’t turn as far to one side is a blessing.... it could have been much worse than an embarrassing 3 point turn.
I assume that there was a nut on the end of the sector shaft or the pitman arm would have already come off.
The center arm assembly bell crank arm is undoubtedly bent. Both the pivot and the ball joint taper should be parallel and they are not.
If it’s any consolation, you’re not the first guy who’s been told to cut everything out and start over.
The worst are the guys who’s PO chopped the crossmember under the radiator and had to replace the frame just to get back to the starting line. I had to do that once on an FJ55.
Geez. This just gets better and better.:deadhorse:
I appreciate very much your comments and suggestions. I was gonna take it to the mechanic down the road, but this is Ecuador. He might think it's in good shape. Anyone know of a good therapist (mental) in southern Ecuador? :bang:
I guess I'll find a place to put it while I tear that apart. I just got it back 2 weeks ago after a one year stint getting the body restored. (which by the way, the guy did a horrible job). I was hoping to get it done and drive it a little before they take my license away. (old age)
I'll post any new findings and fixes.
One more thing. Other than the pitman arm , everything else should be perfectly straight?...the relay rod, the tie rod and the drag link?
Here are some more pics from today's inspection. I used string to help show the bend. Isn't it odd that the rod is bent down instead of up?
Yeah the u-joint thing...I was thinking about that before but for rotating the pump so the pitman is horizontal
As of now. the steering is working somewhat acceptably. The mechanic said it was the tie rod. The box and pump screech and cry but it turns now.
I am quoting this only to preserve it for posterity. Please tell me you are not seriously considering leaving that POS setup on your rig.
Don't have much choice. This is a 3rd world country with limited resources. I will keep looking for proper equipment. I will probably find it eventually. Can't just jump on the internet and find a part here. There's a lot of networking involved here. I'll find the right person who knows somebody whose uncle has a brother-in-law that knows of a guy in Quito that has some parts. I just have to be patient. Thank you all for your help.
