No more cold feet.
. Thanks for the tip Phil.
Was this an exact fit?? I ordered the Toyota seal, but this seems like a much better way to go for only a couple of dollars more!Did mine today, 45 mins to fit.
This is what I used (2 weeks to get delivered from the States though !!)
http://www.ebay.com.au/itm/330663749889
Will never have to worry about it again !
Pretty much, fit nicely on the shaft with no slop but had to grind it down a little at the top and bottom to fit better and needed slightly longer bolts, other than that easy ! Its was even cheaper to buy one of these and get it shipped over than to buy a genuine one.Was this an exact fit?? I ordered the Toyota seal, but this seems like a much better way to go for only a couple of dollars more!
Just replaced mine with the bearing solution..as previously stated the securing ring needs reprofiling to replicate the OEM seal and slightly longer bolts to secure the plate and bearing to the firewall....
Makes me feel better knowing that the shaft now no longer can contact the firewall and is almost blocking elements as well as the rubber dust cover
3 minutes grinding (I just clamped the plates together with some vise grips and hit them on my grinder), and bolts 10mm (3/8 inch) longer-too easy. had the bolts at home, standard m8 bolt.
I just replaced mine with Oem. the bearing option above looks great. But I wonder if you will get vibes in the wheel since the Oem was meant to have some Give.
Good Info
Is the firewall bearing support installed alone or in addition to the shaft seal?
Thanks
Brando
