Hood Alignment
My fj has been taken apart for about a year now since then I've cutting out and replacing the rusted metal in the tub. I have nearly all the metal work finished and am now mocking the body back up on the frame. I also purchased a set of ccot fenders and everyone is right when they say they are a pita. I've got them to where I am pretty comfortable with the look, but I can't seem to get the hood to line up perfectly flush with the front bib. My question is does the hood normaly hand over the bib by fractions of inch or do i need to keep working the fenders to where there is no overlap on the front? From 5 feet away you can't see the overhang, but up close I notice it. I've search for many pictures but none of them are close enough for me to actually tell. Any help would be great. I know I should have gone with oem fenders. Trying to get it all set so that I can take it apart again for paint. Thanks
mine is just the opposite. The never quite line up perfectly. You can also try adjusting the hood hinges back , they have some adjustment in them.
Good luck.
It is supposed to be flush. The clean, strait, symmetrical trucks that I have seen and worked on have been this way.
Good luck!
-Steve
Thanks people thats all I needed to know.. Looks like I might go with oem fenders, we will see after this wekkend. I am going to give it a couple more days to seeif I can't get these ccot to work. Thanks
It can be a chore with those CCOT. I drilled out some of the tack welds, fitted the fender, then welded it up again. This was to get the aprons and front bib to fit well, hopefuly I won't have a problem with the hood..
When you install the fenders, bib, hood, and aprons leave all bolts loose so that you can move the parts. That way when you're trying to get it all lined up all of the pieces can adjust to each move.
It's hard to explain and can be pretty frustrating but if you take your time and use blocks and wedges and whatever else you think might help it'll eventually come out right. I had to use a hydraulic power pusher to bring the front end parts of one of mine into alignment.
It's like a small scale body shop setup where they use rings mounted in cans set into the cement floor with chains and comealongs to pull, push, and tweak from all angles to bring wrecks back into shape.
GL
This is frustrating to read about because I'm nearing time that I want to replace the front fenders.
Is there a better option than CCOT to save me grief, even at a higher price?
A pic would help me identify your problem. You say the tub was off. Is the gap between the back of the hood and the cowling uneven? If so, you may need to shim up the body mounts. Loosen all the body mounts except the four across the rear sill. Shim the tub upward at the front most body mount and see if that pulls your hood back in. Mine was out of whack for years until I figured it out, now it looks factory correct.:)
Igotta40,
Thanks I tried that last night and it worked perfectly. the hood and bib alignment is perfect. It only took 1 washer on each mount to shim it up enough to fix the problem thanks again.
GL
This is absolute. I tried several ways and "happened" onto what Honk is saying. I loosely bolted everything together and used a Port-O-Power ram on the bib hinge from the frame rail and got everything pretty well aligned.
Glad you got it!:)
Ed
Glad I could help. Make sure there's no gaps between the body & frame at all the other mounting points. You don't want the body tub to taco on you. I had to put in three washers in front, two in the middles and one each on the rears.
