hj45
Welcome to the fun...
Met a guy in Grand Junction that has a FJ45 1965, he has had it for 45 years.
Seems pretty straight. The exhaust looks a bit patchy but the rest of it appears solid.
Any Diesel H motor experts out there able to chime in on the things I should check/service first?
On my 83 HJ47 (with a 2H motor), once we sorted out all of the glow issues and got any faulty parts replaced with OEM all of my starting issues disappeared.
It's a much more elaborate (others would say overly complex) glow system than your H motor, but I still think the experience is relevant. I was using ether to get it to start each time. Now that the glownissues are sorted it starts first turn every single time.
I've been working quite a bit on it lately. I found a disc brake front end and am swapping in the knuckles and adding 1982 FJ40 front discs with 1990 V6 Truck calipers/pads as well as a Birf/Knuckle rebuild. I also found an Aussie Locker for the rear, some 15" steel wheels and am ordering some 33" BFG Muds.
I replaced all the glow plugs, cleaned up some wiring, replaced all the filter/fluids, resealed the front diff and transfer case and other misc items. I also picked up a 1970 heater assy from another member and am pulling together all the parts to make that work too.
The work goes on...
Great looking truck. A defroster should come in very handy here in Colorado. I wonder if any 3rd world country FJ45 has ever had an exhaust system that wouldn't be described as 'sketchy'!
Heater for sure! I was able to find all the ducts, even the side defroster ones :) You can tell over the years that the exhaust was cut/patched/welded where needed. Looks like the front tubing is not avail anymore. Will have to take it to an exhaust shop for a custom one in time.
