what are you doing with the inner fender? gonna try to pull and straighten?
but that is what the rad support goes to, inner fender-rad support-inner fender are all spot welded into 1 piece.
the outer fender is like the bumper cover, not structural, more cosmetic.
a small come along and a pair of vice grips with a ring welded onto the back is your friend! You can use it to pull selectively against anything heavier than your truck... trees and fence posts work well. It's amazing what you can do. Remember to pull the opposite direction of the accident.It's hard for me to tell where the inner fender stops and the radiator support begins. I can bend it by hand a little right now so I'm hoping I could bend it close enough with tools to tack it in.
The truck had some replacement bulbs that said "morimoto XB" on them. There is some additional wiring and small boxes for them under the hood. I'm hoping I can easily replace the lights and that all the wiring is there...
I happen to have a new Lexus OEM: SUPPORT SUB-ASSY, RADIATOR - Part No.: 53205-60040 and HOOD SUB-ASSY - Part No.: 53301-60520 in my garage that are leftover parts from a past similar repair project of mine. I decided to go a different way with my repairs once my paint and body guy dug in to complete the repairs and did not use either of these parts. Both of them are as comes new from Lexus (except for the hood packaging which FedEx completely destroyed) and primed but not painted or clear coated. PM me for details if interested.Radiator Support for 1999 Lexus LX470 | OEM Parts Online
www.thepartsspecialist.com
I'm looking at just getting the "upper tie bar" and two side panels. The whole assembly is $554.
Agree with @gungriffin — headlights can be had for cheaper than that. Brand new ones should be just barely more than that.
Pretty sure that the radiator support and inner fenders are steel not aluminum....Those boxes are ballasts for the HID lamps. Should be no problem to remove them o the aftermarket light harnesses.
This is probably a stupid question, but the inner fender and radiator mount are steel not aluminum correct?
I'm worried now that I'm missing the factory headlight wiring. The PO had replaced the inner part of the lights with some type of HID deal, the wires go into these little black boxes mounted on the fender and a bundle of wires near the. battery as well. What is all this? Anyone know how hard it would be to replace those so I could install the kit mentioned above?
I think he retrofitted the projectors. I pulled one out of the old busted housingYou definitely have aftermarket HID headlamps. The item that is unknown is if the previous owner also retrofitted a projector housing into the headlights. If they did, you will need to either revert back to stock (which will now REALLY seem bad) or convert to a projector housing.
