Hit a deer...
Got the bumper and grill off today, tried to get the fender.
Only thing holding the fender on at this point is a few torx screws....I dont have any torx bits so I've gotta pick some up. I also gotta figure out how to remove the antenna so I can get the fender off. I swear I hate these plastic clip things that hold the plastic wheel well on, I had to break all but 1 to get it out.
After removing the grill i found out the hood is bent. I couldn't tell before, but now with the hood latched there is a gap between the fenders. It's bowed up slightly. Hopefully my body guy can repair it, a salvage one is like $750 before paint.
I'm going to have to drain the A/C system and disconnect a couple lines before I can remove the radiator support. Also, aren't there a couple of lines from the transmission going to the radiator? I'm going to try and plug those so I dont have to refill the tranny.
I'm trying to take this one step at a time so I don't get overwhelmed. It sucks because I'll be out of town for work for a month in a couple weeks.
Fender liner push rivets here: Amazon.com: PartsSquare 20pcs Fender Liner Fastener Rivet Push Clips Retainer Nut Compatible with Toyota Land Cruiser 1998-2010 Compatible with Toyota RAV4 2000-2010 Compatible with Lexus LX470 1998-2007: Automotive
IIRCC the trans cooler is in front of the rad, not in the rad.
the hood is most likely bent at the relief area on the hood ribs, not sure once it is bent how to correct it and keep it from bending again. if it gets straightened it will have the weak point where it bent already and will want to flex there again.
I went and dropped the truck off at the guys house who does bodywork on the side. He said he could straighten the rad support, and fender, paint all of it for $1500. He's going to try and straighten the hood, if not I'll get a new one and repaint it. I'm going to pop the lights in and new bumper on myself. Seems like this guy knows what he's doing since he has a decent shop behind his house and he showed me some of his repair work which was pretty impressive.
We'll see how this goes.....
Went back and forth between ARB, TJM, and Ironman bumpers. I really wanted the Dissent, but I just couldn't swing it. I just ordered the TJM T13 outback deluxe from AutoAnything for $1,164 shipped. I was pretty happy with that since everywhere else had it for $1,300+.
A deer isn't going to slow me down this time.
I’m pretty sure that you will be happy with the protection. When I mounted my TJM I realized that my frame ends were warped by a previous fender-bender, and required massaging . Given your truck’s history, don’t accept anything as proper.
Keep us posted on that T13. I'm currently debating the T13 vs T17 vs ARB.
I really like the T17 the best, but I really need the extra protection.
well I got her back today...I think the guy did an excellent job on the fender. I cannot even tell unless I look really close at the areas that will be covered up by the bumper and trim pieces.
I couldn't wait so I went ahead and installed the TJM bumper. Man, this was the most tedious thing I think I have ever done to a vehicle. So many parts.... So many unlabeled bolts..... I screwed myself because it was looking like the winch tray would fit without cutting the frame horns off...that didn't work out. I had to take it back off and cut them.
I was worried about the wiring but that part went pretty smooth. I wired up the fog lights to the stock wiring and tested them four times. Of course as soon as I put the bumper on now they don't work:bang: I'll have to figure that one out later. Turn signals work at least, although I did lose one of the bulb fittings in the accident so I won't have an upper side light for turning, only the lower bumper one until I replace it.
I have the bumper on now, but I haven't tightened everything down just yet. I need to figure out a good way to make sure everything is lined up well. Does anyone have an advice for getting that done? Another issue is one bolt holding on the tow hook (passenger side) will not thread in. It came out perfectly fine, but it feels like the threads are gunked up or something and I don't want to force it. I May just have to throw some washers on that one and shim it up.
I also still have to cut the tabs off the top of the bumper so I can close the hood once it's torqed to spec.
I have the final trim piece coming that goes under the headlights. Should be to the body shop in a week or so for paint.
Thank you for keeping us posted on your progress! One question: in what way did the bumper not fit without cutting? I have heard some folks say they were able to install the T13 without cutting. Since I am likely going with a T13 and have the same year and model as you it would be great to get some extra details. Additionally how did you end up wiring the lights?
Cheers,
Scot
Cheers,
Scot
The winch tray would fit on without cutting, but when I got to the point where I had to insert the bolts in the frame to attach the "bumper angle" as TJM calls it, it wouldn't fit. These bolts have a piece of flat stock welded on them I assume so that you can fit them into the frame and guide them into the holes with the frame horns still on. That part worked, but now you have these 2 pieces of flat stock sticking out the that space between the top of the frame horn and the frame end, so the mount wont fit flush like it's supposed to. You could get away with it if you cut the welded flat stock off the bolts ( I don't think you really need them anyway), but I don't have a vise so it was easier to just cut the frame horns off with my grinder. Hopefully that makes sense...
For the lights I ordered some LX head lights from a guy on here who was parting his cruiser out. I really only needed the passenger light, which hooked up fine and works. My driver side HID still works, so it looks a little wonky right now with 2 different color lights. I think I'm going to just replace the driver side light with a stock light so it matches.
The turn signals were easy, I just cut the stock turn signal wires and soldered them in per the TJM instructions.
For the fog signals I just cut them at the stock connector, and soldered the 2 wires from the TJM fogs into the stock wires. I can't remember the color, I just tried them both ways until it worked, then soldered them. The bumper came with 2 fog lights and all these extra wires and even a switch and relay. It was meant for a truck that didn't have fog lights installed originally so you won't need any of that.
Once you're done definitely post some more side profile pics and im curious to see the amount of rake with the added weight to the AHC. Looks good so far!
First one in N, other two are high mode.
I'm going to try to get the pressures with tech stream tonight or tomorrow....its going to involve bringing my desktop to the garage since my laptop is busted
In theory, (within limits) adding weight to an AHC vehicle shouldn't affect the rake.
Holy s*** i love this. What model TJM is it?
I'm pretty sure it's the T13 Outback. I got it from Autoanything.com
I wanted the Dissent full bull bar, but I couldn't afford it. That thing is beautiful
Im liking the TJM more so, and I originally havent been a fan of the tan color LX but im currently looking and would get one now that I've seen yours.
The turn signals were easy, I just cut the stock turn signal wires and soldered them in per TJM
Thanks, that’s exactly what I was curious about😁
For anyone interested these were my pressures after the bumper. I started the truck went to low, then to N. (hopefully that's right)
Fronts started at about 7.0. I cranked 7 times on each and they ended up at 5.5 (oops) i dialed them both back 4 turns and ended up here
