shocker said:The IPFs are the same as all the other HIR bulbs, as I beleive Toshiba is the only manufacturer.... IPF just rebrands them.
Ahh, didnt know that! Thanks for the info!
Boston Mangler said:Anyone know where to find these 100w hellas?
Beowulf said:Don't waste your money on the Korean 100w Hellas. They are pure crap. Mine blew out after 2 minutes. Too much of a PITA to try and get them exchanged. You might be able to find the German 100w bulbs if you're lucky.
Boston Mangler said:Thanks for the heads up, any idea on where to find the Germans?
LabRat11 said:The high beam will need to be acquired elsewhere.
Time now to order that wiring harness from Slee......
Boston Mangler said:Sweet, i just came across these:
http://www.jcwhitney.com/autoparts/...rowse/s-10101/Ntk-AllTextSearchGroup?Ntt=9005
LabRat11 said:However, If you'd rather do a little rewiring the bulb sockets are also available.
FZJFillmore said:Somwhere, Cary is twitching.
I concur - I plan on doing the bulb mod myself. Just pointing out the fact that the sockets are available from Deere should anyone want to take that direction.shocker said:Anyone who would do that is a fool, as the modifications to the HIR bulbs are so effing easy. .
How do you verify that the bulbs have the coating?? Visually?? Check the paperwork??shocker said:When you get the bulbs from Deere, check to make sure they have the infrared coating. .
Good to know - anxiety level far lower now.shocker said:HIR2's have always been the low beam bulbs, HIR1's are the high beams. Maybe Deere is just now incorporating the correct nomenclature into their ordering system.
s and
shocker said:They'll look like the ones in the ebay add. Kind of a purplish hue.
The non HIR ones would probably be perfectly clear.
sBoston Mangler said:Sure, i am impressed with my HIR's for my lows, but i am looking for something VERY bright for my highs!
mot said:What do you have against going with a good pair of aux. lights if you want BRIGHT.
I think one of the last things you want to worry about is having your lights give up the ghost while driving in BFE or in a foul weather (in that case you wouldn't want highs anyway.).
mot said:I guess I can understand your point of view that you have tried something similar in the past with satisfactory outcome
mot said:Please keep us posted as to what you end up doing and how you like/dislike it.
Mot![]()
