So...how would I know what the PO has in there? I'm really happy with my Highs after the Slee Harness upgrade...the Lows are better, but could still use some improvement. What are the indicative markings?
General said:What is an HIR and an IPF?
LabRat11 said:Any way to confirm that these bulbs are 'THE Bulbs' ???
Safado said:what are people talking about with the 9011 and 9012? Do they superceed the 9004 and 9005 or are they better?
boekppl said:For everyone's information there is a very slight mod that needs to be done to the HIRs. One of the retaining tabs that holds the bulb into place needs to be slightly trimmed down to fit. I used a Dremel tool and it took about 30 seconds to do it. A file will also work, and I've heard of people using nail clippers! The bulb holds secure, identical to the stock bulbs.
shocker said:The IPFs are the same as all the other HIR bulbs, as I beleive Toshiba is the only manufacturer.... IPF just rebrands them.
Your high power 9005s (Assuming they are the Korean Hella bulbs) might last you a bit, but most have lasted about two months or so. Their filament stands a good chance of being poorly placed as well, causing your beam to be unfocused.
Go with the HIR high beams. The light will be focused where it should be, they'll last you forever, and they only output a little less light than the 100w Hellas.
