HFS springs?
Here is what I found out. According to BDS they do not have any affiliation to HFS. I had heard the same arguement that HFS was made by BDS so I specifically had a retailer ask that question. BDS does deny any affiliation with HFS. This does not mean the don't make them, just they don't want anyone to know they do.
BDS does have a lifetime replacement guarantee on their springs, so if you are having any sagging issues, they should replace the spring without any questions.
As for more springs in a pack meaning better ride, I disagree. I bought OME springs(heavy front, 7 leafs, and heavy rear, 7 spring, I figured I tow and load every once in a while) and the complete OME lift kit. After installing and driving the FJ40 a couple of months I could not take the scrambled brain from the stiff springs. I called ARB who said just take out the added leaf in the rear to make the spring into a medium duty spring. I did exactly what they said, and the ride was much better. I ended up selling the 40, but if I didn't I would have taken another spring out of the rear, and one out of the front, which I believe would have been the perfect ride. I did have a brush guard, and winch on the front, and still the heavy springs were too much.
As for the rest of HFS claims, BDS and HFS have the same type of poly spacers, military wrap, etc.... I know with OME that added leaf I took out helped with towing, I bet BDS has the same type of spring you could add to your existing pack to help with the large towing weight.
I do think HFS is a good quality spirng, and would last and ride well, but I don't think it is the saving grace for cruiser suspension. There are others out there with great rides as well. Just stay away from add-a-leafs, long or short, and I am not a big fan of skyjacker.
Just my 2+ cents, I hope this helps
Scott
Scott
You misunderstand. The spring manufacturer in Canada is the same one that makes BDS as HFS. Same plant, different specs is all.
It is a fact that more, thin leafs can give a better ride as less thick leafs.
I know what you are saying in that more is not better though. I had a set of Alcan's that a guy sold me that had been built for overload on his FJ-55. The rears had 9 leafs and they rode like s***.
They were designed though for 2000# overload so when I installed them on my Pig with no load they were horrible.
I removed 2 leafs on every corner and they still were too stiff.
As for HFS being the "end-all-be-all" I did not say that either.
Whey Stephen came to me and asked what were the most popular choices in lifts out there we took Skyjackers, BDS and OME and looked at all 3.
We saw what each offered and tried to improve on the concepts.
I think they are great springs, but that is why we have choices out there.
CCOT was the #1 seller of FJ-40 BDS springs until they designed the HFS line. They too believe that BDS makes a great product, but when you see 15 lifts a week going out your door it is time to do some of your own research.
#1 complaint they had with the BDS system was vertical shackles and a harsh ride until the springs broke in.
About 25 sets of test springs later, the HFS system was born.
That's the story.
In addition to what Nolen has said, another of LSLC's club members installed the HFS 4" last year for the Lone Star Cruiser Roundup...he's the one who did a write-up on the install for TT. Anyway, at club meetings, month after month, I ask him how he likes the lift. It's been nearly a year and he still raves about the springs, the improved ride/handling and has reported no sagging issues. When the lot is full of lifted 40s, I can look at his next to a rig with another lift and see the difference in spring length and shackle angle.
If CCOT does offer the HFS in 0-1", that's what I'll use when I go SOA.
Garth, how much gear is he hauling on the back. I have a heavy tire carrier/hi lift/beer cooler....I mean jerry can carrier from MAF. I love the carrier and don't know what I'd do without it but it is friggin heavy.
To make it worse the 35" spare and the fat boy drive'n are ont he same side, so the left rear is starting to sag. To make it worse, although the springs were new when I installed then, I'm not the 'original purchaser' so the BDS warranty does me no good. I know I'll get through this year by swapping the springs side to side, but by next winter they'll need to go.
Here's the carrier, almost loaded. Sorry pic kind'a sucks.
I've probably got the longest experience with the HFS 4" lift. I demo'd them at the Round-up last year and wrote up the TT article about them. I still love them and have experienced ZERO sag. I know this because my soft top would bearly rub the rubber flap that hangs down from my garage and it still does. I must admit that I don't run a ton of weight in on them but feel that a little more would make them ride even better. My current set up is:
Pakastani soft top and tailgate
heavy 2F
heavy PTO winch
Stout Tow bar
PTO gear box hanging off xfer case
stock tire carrier with 32" swamper SSR radial with highlift hanging off it
box of junk in the back that probably weighs 65lbs
co2 bottle behind pass seat
I plan to drive it down to the round up again this year.
Hope this helps, feel free to ask any addional questions.
7/77FJ40
Posts: 1?
Holy crap, glad to finally see you on this board! *Should* have tha paki top on by Roundup...
GreenFJ40 is the guy I'm talkin' about, so check his post.
Goddard? My family and I make the drive from Dallas to McPherson on a monthly basis. My trail rig is currently in my sister's barn in McPherson. I'll be Cruising it back to Texas this month or next. Glad to hear you'll be at the Roundup...I'll be the guy handing you your registration packet!
-Garth
Hey Garth, glad to hear you're making progress on the top! yep, I've been lurking around and that was my first post :)
hey green, how do those springs flex? i dont know the meaning of flex cuz i got rancho pos'.
I'm very impressed but really had nothing to compare to besides the flat original springs I replaced.
Here is a pic from my article:
http://store1.yimg.com/I/coolfj40_1819_385513930
It was very difficult for me to tighten the U-bolts without any weight on them when I installed it. With no tires installed, I had to use my HiLift and jack it up really high just to get the Ubolt plates far enough off the ground to get a socket wrench under them. With the postitive shackle angle as the tire drops, the shackle hangs straight giving you that much more droop. I'm really not sure what it would take to get some air under the tires but maybe I'll find out this year at the round-up :)
oh yeah i read that one before. im really debating with what lift to go with. let me know anything else that you think may help my decision. thanks
195 a corner for alcans is screamin considering you get to call out the specs you want ,
vehicle weight
spring length
center location
ride hiegth
you get to custom set the front to rear difference for when the rig is loaded with gear and you get the shackle angle on the nut.
they flex well too
cool
Thanks for the pictures.
Looks good, nice to see springs that are long enough, with regular 2.5" shackles on my 72 FJ40 with the Skyjacker 4" springs, I've smushed them against the chassis more than I can remember.
Now I just need to decide if I'm gonna get the HFS 4" springs w/35's or 5" springs w/36's.
Basically contemplating all of the angles and if I feel like 5" springs with 2.5" shackles are or are not going to be too much that will require a lot of cutting.
I've never really worried about angles/steering too much with lifts 6" or less, but 7.5" or so changes things.
