HELP!!!!
NOW in Texas
Hi everybody!!!
I am new to this site and I'm very excited to be here. I own a 95 FJ80 with no modifications...yet. I recently took it up to Slickrock road and deer valley trail here in Cali. Awesome!!!!!
Anyways...I need HELP!! An hour ago I run through a puddle of mud at some construction site. It was a pretty big puddle and long too. Anyways, the engine started stalling after I finshed. I have a pretty good idea what happened. I think I got some water into the engine. DOES ANYBODY HAVE A REMEDY FOR THIS SITUATION?? I'M NO MECHANIC BUT I LOVE MY FJ80. PLEASE HELP
You could have just soaked the distributor and now it's misfiring. The only way to get water into the engine is through the air intake. Check the air filter and distributor. My .02
I had the same problem after spraying at the car wash. I definatly got something wet, but it cleared up after a few miles. I even tried to stay away from the distributor. I'm interested in what other peoples experience is with this.
Two places most suceptible to water when you wash your engine (I cover both with towels) is the distributor and the wires coming out of the MAF from the airfilter output.
Might take off the distributor cap and see if there is water and dry it out. If water did get in there, probably good to get new cap, rotor and wires in the futire as the O ring on the cap should have kept it dry unless it gets old.
X2 what Romer said.
You could let it dry out over night and see if she fires up in the morning.
Often the ignition (sparkplug) wires get pulled slightly out of the distributor (or were never properly pushed in by the last mechanic; this can allow water to get into the contacts inside the distributor cap towers. You can pull the wires out of the cap (one at a time) and put Q tips into the towers; check to see if they come out wet. Clean (as below) and reconnect the plug wires. If water gets into any of the electrical harness connectors, the engine can run very poorly, or not run at all. These however, IME, seal up pretty good. I would focus on the plug wires at the distributor, the MAF connector and the distributor connector, as well as the cap itself as Romer stated.
Good opportunity to buy a can of CRC electrical connection cleaner and some Dielectric grease, expensive for the CRC brand, about $7. Do not use any grease, just DIELECTRIC grease which is specific for electrical connections to prevent corrosion,etc. Then carefully disconnect the harness connections by squeezing the center tab and pulling gently holding both sides of the connector. Inspect for water, dirt, etc then spray clean with the CRC, allow to dry (seconds), apply dielectric grease, snap back together. That's my routine.
Oh yeh, stay out of the mud, and water.:)
although it was a pretty big splash of water and mud...i'm afraid water actually got in through the air intake. i'll check the distributer
It would be difficult for water to actually get inside the intake and into the cylinders just by splashing; how high up was the water? Did it come into the cabin with the doors shut? Pop the cover to the air filter (muffler/can/assembly) and carefully (without bending the rubber air intake tube/hose) and check the air filter, look for water. While you are at it, you should probably look for mud, dirt, grit (everywhere). Dirt and mud stuck in the cracks and crevices of the frame and body will hold water, and accelerate rusting down the road.
The 80 is a tough beast, but it is not a submarine.
Storytime; many years ago I brought home my brand new FJ-60, only about 60 miles on the odo having driven directly back from an out-of-town dealer. My best friend walks up literally as I pull into the driveway. Says, hey, can I take it around the block? I say, sure as I hand him my keys. Mistake.
He takes it to a nearby construction site full of mud holes, pot holes, cement piles, gravel, sand, etc, etc, etc. Thinks he is driving a Sherman Tank onto the beaches of Normandy. He completely trashed my sparking new LC; totally covered in mud and goop, dust, etc, etc. Took me a week to clean it up. He never drove my LC again.
Lessons learned: Landcruisers are not submarines or mudtanks, and never give anyone the keys to your LC (at least not if there is a mudhole nearby).
It wasn't that deep. I just ran into it pretty fast and hard, which in turn spalsh a whole lotta watter on the LC.
The air intake is inside the passenger fender. I don't think it's possible to splash water into it, and certainly not enough to cause a problem.
-Spike
Oh yeah one more thing....the engine light came on. Could that still be the distributer?
If it was running rough, meaning cylinders not firing, yes it can result in the MIL light to come on.
Take it to Autozone or other parts store and ask them to run a code for you, and clear it. Sometimes they won't clear it; ask them if you can do it; you just follow the prompts on the screen. If they still won't do it, you can just disconnect the negative battery terminal for a minute. After that, the first time you start it, it will probably idle high, then low, high low for a few minutes; it is just the ECM (computer) relearning; do not panic. Let it do it's thing and after about 3-5 minutes it will settle down and you can drive away.
Come back and post what happens next.
ok, gray. thanks for your advice. very much appreciated.
Spark plug socket
I just recently purchased an 97 80 CE and needed to clean the engine, so after a good steam clean it started running poorly as well. I thought it may be the rotor cap but it was dry. After removing the spark plug plastic cap I discovered that whoever intalled the spark plug wires had ran one under the number 3 plug cap so water had filled the entire plug socket. Being a good husband I grabbed my wifes turkey baster and sucked up as much as I could by taping a straw to the end and then using q-tips taped to the straw to dry the rest.
Not a pretty solution but it worked great and ran like a champ. The problem with the design is that water gets trapped in the channel for the wires and if the plug cap is not sound it fills with water. Needles to say I purchased a new turkey baster after it was discoved and now have a new tool in my tool box for these occasions.
another thought: for maximum help, put some content in the subject.
