Help with Wit's End Auto-Up Diode
San Jose, CA
Installed the Wit's End Auto-Up Diode....and it didn't work. :( Made sure the diode was installed in the correct direction
Here are some pics... see anything I may have done incorrectly?
It looks right. It's easy to get this wrong, if you don't pay attention to the circuit layout, IIRC. I would desolder it, reinstall the board and perform a function check, just to make sure the board hasn't lost a circuit somewhere. Also, check the diode with a multimeter; it's rare but it is possible it's bad. Then try to install it again.
Good luck.
I know this is an older thread but did you ever get this problem solved? I'm getting ready to tackle this problem myself and want to get my ducks in a row before I mess anything up.
It looks like you installed the diode correctly, but I don't see any mention of whether you modified the window switch to allow it to rock to full extension. I'll try to find the thread I was reading where that step was mentioned...
Here's the original thread from the FAQ.
I did this last week. The pics above show he did everything correctly. And yes, trim down those two tabs and everything will work.
