I use the MORRFlate quad hose system connected directly to the compressor. I inflate 4 tires at once from 12-15psi to 41psi. It takes less than 5 minutes.
The MORRFlate hose diameter is is 1/4" vs the ARB 1/8" and this seems to effectively dissipate the heat. While the ARB hose material is stronger/more durable, I find that the larger diameter of thge MORRFlate is much more efficient for my purposes.
I've used this +/- 10 times and can see no degradation in the hose or coupling yet. Will certainly keep an eye on it.
Yeah, they use flexzilla hose and it is very high quality.
