Help! What could this howling be?
So ive been having this annoying and quite noticeable howl.
1. At around 40mph I get a howling noise, but only when I push the gas pedal down to a certain point. The second I let off from that point the howl disappears.
2. I have changed the front and rear diff oil and the transfer case oil. I also changed the front wheel bearings and both front driveshaft u joints and added 1/2 tube of moly to each knuckle.
3. When I drive in HI with the CDL engaged the howling is gone, but I get a new noise, a loud clicking when I turn sharply left or right (I also didn't remove either drive shaft when doing this as I was driving home from work when I decided to try and lock the CDL)
4. Can also feel a slight vibration when my left foot is on the foot rest.
To sum up, a howling when accelarting at around 40mph which disappears when I let off the gas and when the CDL is locked. And a loud clicking when doing sharp turns only when the CDL is locked. The two noises are never present at the same time.
What do I do now?
Im not so sure driving at 40+ with the CDL locked is a great idea.
Anyway, I get the same howling, and my searches have lead me to believe it is a pinion bearing in the diff. Someone also reported replacing their drive flanges and the noise went away. Clicking on turning points to worn birfs.
Im sure some experts will chime in soon with much deeper insight than I can provide.
I agree with Pippy. Clicking while turning means birfield problems. I would rebuild the front end with grease and seals, and change the birfield joints from one side to the other. Get plenty of grease in the spindle bearings and see if that takes care of the howling. Just be aware that if the front diff has to come out to fix the pinion bearings, you will have to pull the front apart again enough to pull the axles. I would get at least 2 extra inner seals when hunting down parts just in case you have to go back inside. What was the reason for not going all the way when you did the front bearings?
Fix what you KNOW is wrong first, then go from there.
The one thing that bothers me is that the CDL MUST be on to hear the clicking. Birfs usually will click either way when needing service. Are you sure it is clicking, and not the front end binding up because the tires can't slip on pavement while the CDL is on?
Driving with the cdl locked above 40 is fine as long as you are on a surface with compromised traction (snow or dirt). Almost all part time systems utilize a transfer case that splits power front and rear 50:50 all the time when engaged and they do fine.
Had a howling and screech from the front end briefly. Neighbors cat. Some fuzzy stuff for a while, reeked pretty bad. Parked it at the ex for a few weeks, it had stooped stinking by then.
Elhombre has the same questions I do, and the fixing what you know is broke is honest too.
I would fix what's wrong, but I don't Know what is wrong. That was why I was seeing if anyone had some other advice on what to look at next besides the stuff I already listed above.
I get a hiss noise when I'm driving around that speed. But I think mine is due to a leak from the cat or the exhaust. The hiss goes away soon as I let off the gas
If it's only under load, I would lean toward spindle bushings or pinion bearings. Just filling the knuckle housings with grease does NOT place it in the spindle area that it needs to be.
My rig does the same thing, a bit of a howl under load, and a little vibration on de-cel. 4º + caster, brand new DC shaft & joints, axle rebuild, new fluids, etc. I'm certain it is the pinion bearing, but I'm sending my thirds to Zuk soon for an inspection and new gears - can't wait!
I have had the same type of whistle or howl on all my FZ's, its normal.. The noise comes on only during load..
