Hey all ! A little background first. I recently purchased an '84 FJ60 with the intent of learning to work on vehicles while I fixed her up. I plan on having the vehicle inspected by someone with much more knowledge than I but I thought I would start with some basics like changing oil and flushing the coolant etc.
I did my first ever last oil change Friday and it was a success! So naturally I figured "you've got this...lets step it up and figure out this coolant business". I went and purchased 8 qts of coolant and some distilled water as well as some radiator flush from my local Napa Autoparts........everything from then on went south. According to the FSM there are two 'draincocks', I was unable to locate the one on the driver side of the block and ended up only draining from the radiator...is this bad?
When I first drained the coolant it was green but it gradually became more of a brownish color. Additionally I drained only 12 qts(I believe capacity is 16.9). After draining I put about 8 qts worth of water into the radiator cap before it would not take any more.....this was the first sign that something wasn't right. After some research online I ended up reading up on 'burping'. Followed what was suggested.....*boom* no hot air..
Image explanation:
1.The first attached pic is actually the water I drained from the radiator after having drained the coolant. 2.The second image caught my attention because of that rainbow sheen....is this oil?
3 & 4. Taken while attempting to 'burp'.
Any advice is appreciated! I am a little freaked out as I have never done anything like this before.
Image explanation:
