Help w/ Coolant
I don't know if it overheated. I suspect I need to replace the thermostat because the gauge doesn't seem to move even after running her for 1/2 an hour.
As for the idle issue. Ran for about ten minutes earlier. Turned her off and then tried starting her to move her and she died on the first go. Initiated the choke and tried again with no problems. Reading up on the ICV now.
For clarification, is flushing the coolant by only draining the radiator with coolant flush, and refilling with fresh 50/50 all that is actually requires for a radiator flush?
I just did one while changing my thermostat and didn't drain the engine block.
flushing the system requires installing a plastic "t" in your heater hose. You have to cut the hose and hose clamp the T in the line. The T has a screw cap on it. Take off the cap and attach a garden hose to it, taking off the radiator cap, turn on the hose, turn on the engine. While the engine gets hot, the fresh water pushes through the system and overflows everything out the top of the radiator. When your done you drain the water out of the radiator (and block if you want). there is a plastic pet cock on the bottom pass side below the battery let it all drain out. then fill with anti-freeze/water mix.
If you just drained the water out of the radiator and filled w/ 50/50 mix your not going to hurt anything. Just gonna have some old stuff mix with the new. just realize you can get air/steam etc trapped in the block and have to work to get the anti freeze in it.
You said you ran it for 30 mins and the temp gauge didn't move off of cold. I suspect your temp gauge is off. Can you put your hand on the breather and see if things are getting warm? What about the radiator??
Radiator gets hot. The return line is spungy. Going to get a flush kit after work today. Maybe a 9 volt to play with the ICS as well.
Handy man came over to fix a couple of things so I had permission to come into work a little late. Tinkered around etc. Didn't really want to get crazy but I ran her for about ten minutes. Checked the oil right before I turned her off and there was oil essentially all the way up the dipstick.......
Do not check the oil while engine is running.
John
and let it sit for a bit after you turn it off or it will read a little low. Over the years for one reason or the other, i have pulled the dip stick when it was running, does no harm, but years ago when we had the power out, running a crappy old generator.....I pulled the dip stick when it was running.......it shot about 30ft past my head.....took me an hour to find it in the dark. I felt like a moron...
BTW.......the 2F motor holds alot of oil, 7-8 qts
If it were me, I would just ground the ICS to the carb body and be done with it. If the ground(at the computer end) are not failing, they will soon.
John
I put 8qts in when I changed the oil.
Yeah FSM says 8.4qts I believe... I normally will check the oil about 15-20 minutes after shutting the truck off. This allows things time to cool and drain back down into the pan giving you a more consistent reading.
Agree with @Landpimp about just grounding the ICS and being done with it. If you believe yours is failing then go to Cool Cruisers of Texas (CCOT) and get a new one, they are $15 + shipping. Might as well just get one to be on the safe side, at that price.
Temp gauge may actually be dead on the gauge cluster so talk to @beno about a new one. Go through the process of replacing the t-stat and relevant gaskets (there are two) and if you don't believe that it has ever been replaced order new bolts for it as well just to be on the safe side.
Now do the following and you have a good shot of solving ALL of your so far described issues:
A) ground the ICS as Pimp described.
B) install a new OEM thermostat and two gaskets, 2 gaskets...not one.
C) insure that you do not install the thermostat upside down.
D) use the 'SEARCH' function to learn how to remove the thermostat w/o breaking bolts and or installing upside down or w/o two gaskets.
T stat install is dead simple...BUT... It does have potential issues that you must be aware of.
Do learn how the use SEARCH, and do continue to pose questions here, but you sometimes will not get as prompt of an answe as you may be looking for. SEARCH is always ready to answer you questions.
John
Appreciate all your help and even more your patience! Did a crude grounding this morning. Quickest she has ever started up. Gonna make my way to the store a bit later for a more permanent solution. T-stat and new gaskets are going in today as well.
