Hi all,
I changed the oil in my ’40 on Saturday and upon firing it up I noticed running down the manifold side of the engine in two places. As you can see in the pics, oil can be seen at the top of the manifold as well pouring down below. I know I have a manifold gasket leak (new gasket is on order). Also at the back of the engine (third pic) oil is running down. The oil that is coming out appears to be black which is strange as I had just changed it. There was also come dripping around the drain plug (black as well). Could it be that this is coolant? I do have a lot of white smoke from the tail pipe. It is a 76 2f engine that I was told by the p/o had been rebuilt recently.
(Top of manifold)
(Drip underneath pic 1)
(Rear leak)
Thanks in advance for any wisdom you can share.
Cheers!
(Rear leak)
Cheers!
