What Pin_Head said is good!
And I might add some more stuff:
As I mentioned in my PM to u, get FSM98154 and FSM98126. They are fun reading if nothing else.
I'm just curious if the wiring is stock, but just recovered with tape?If stock, the unique color coding will help with sorting stuff out.
I'm still thinking on this, brain not working well lately.
First off, assume (I hate that word) the engine is stock 1973, stock distributor which means a standard points distributor. There is no ignition module (read transistor ignition Module).
Wish there had been dig cameras back when I owned my '73. By the way, really love ur restore project, now I know why everything is so "shiny ".
Now back to the wiring stuff. I am looking at a schematic for the FJ40 (USA) in the FSM manual #98154 LAND CRUISER REPAIR MANUAL - CHASSIS & BODY. This is one of the best manuals put out by Toyota that I know of. It covers from around 1974 to 1976 or so. The manual is about 1.25 inches thick and has a dark green cover. Toyota started doing industry standard drawing around 1974; pre 1973 stuff is pictorial stuff that is hard to follow. Also FSM #98126 2F ENGINE REPAIR MANUAL; about 3/8 " thick and gray in color. I'm not sure that these manuals cover 1973 FJ40, but they are great and close enough - there may not be manual this good for 1974 and earlier year cruisers.
On the appropriate page (Drawing #98876) in the back of book (far right hand side of fold out drawing page), is one of the few detail wiring diagrams showing the coil and ignitor (transistor ignition module). On top of ur coil is a metal box (shown in diagram) which is most certainly the ballast resistor. U don't have the xsistor module on a 1973 FJ40 (safe guess).This 1973 FJ40 is wired very similar to a 1960's chevy truck. On the left hand side of the page is the ignition switch and starter/solenoid.
Looking closely at the schematic, one determines that there are three terminals. This I am not certain of on the starter/soelnoid unit. There is a "B" terminal, that connects direct to battery. There is a "ST" terminal that connects to the ignition switch with a BW [Black/White stripe] wire; which is the starter solenoid wire; when u turn the ignition switch to START, it applies 12volts to the solenoid, cranking the engine.
Now, the third terminal is labeled "b" on the diagram on the solenoid/starter schematic. The lead from "b" is referenced to right hand side of drawing to the coil + (positive). It is BY [Black Yellow stripe] wire. What this does is short out the resistor on top of ur coil and apply 12volt full battery voltage to the coil for max spark on the engine start up. When u release the ignition switch, the solenoid disengages and the voltage on the BY wire from the starter/soelnoid transfers to the BY wire from the ignition switch; which is connected to the resistor on the ignition side of the resistor. This allows 12volts from the ignition switch thru the resistor and to the + side of coil, a reduced voltage, say 11volts , for engine running condition.
Now back to the "B" terminal and the "b" terminal. What if there is no "b" terminal?
Since I don't know what the starter looks like, I am going to say that the same start-up procedure can be done by connecting the BY wire from the + (positive) side of the coil to the "ST" terminal. [Actually, I know what it looks like from FSM98126].
However, just did some digging in my old archives and found FSM #98126. This manual has drawing and pictures that are outstanding for what ur doing. Starter/ ignition drawing and every thing. Even the terminal that the schematic in FSM#98154 refers to. The pics and wiring drawings have different labels, but are very clear as to what they do in practice.
I recommend getting these manuals [SOR or MANAFRE] or maybe ur dealer or C-Dan can get them.
Well, read this bla-bla and see what happens
Cheers
David in Denver
