Help me ID these wheels pls.
Coweta, OK
These wheels were on my 80 when I bought it. I was told they came off of a Toyota, but wasn't sure which one.
I'm hoping to find new center caps for them, but finding the match is proving to be a challenge.
Hopig someone on here might know what they came off of. What I can tell you, is they are 20's, and the RED caps are Chinese. I'm guessing theyre cheapie eBay replacements.
:beer:
I might be wrong, but they scream aftermarket to me. If they are Toyota wheels they will say "Toyota" in raised metal somewhere on them.
Thats kinda what I was afraid of. they look good, but Ive destroyed all but 1 center cap, trying to find replacements isn't going well.
I just threw up in my mouth a little.
Definitely not a factory wheel.
Find something better and get caps for that set instead
^^This
Besides, has Toyota ever made a 20" wheel for any of their SUV's? (Honest question)
^^This
Yes. 200s and tundras had a factory 20 option
I dont believe those are toyota and i do believe with that massive spacer all the weight of the vehicle is riding on solely the lugs. :eek:
@jfz80 : Thanks for that. Ive been concerned about those spacers myself.
Not seeing a logo or significant markings on either side... so I guess my wheels aren't quite as cool as I once thought they might be. Ha.
I'll prob go back to stock when these tires are done.
I think this thread has brought attention to a much bigger issue than the center caps. You'd be wise to find another set of wheels you like that are a better fit to your hubs.
4RUNNER's also had them
4 runner limited, new 200s all rock DUBs.
So where are your DUB stickers and truck nuts???:hillbilly:
If you don’t go off-road besides some dirt roads that’s not a bad setup. Just make sure you check torque on them spacers once a while, it looks like they are at least 3 inch. At stock height that might work out well for the road.
If you want to do a bit more serious off-roading then all that gots to go.
Wow that has to be like a 3" spacer! Get those off as soon as you can. Don't let the ribbing about style bother you too much, rock whatever you think looks good, but at least get something that fits and will be less dangerous
Apparently only available on the 95 "Oklahoma Edition" ...very exclusive
I agree it's got to go. Im wanting to blame the spacers on the awkward turning radius and it's pretty annoying at certain times.
just gonna let the 1200$ in tires earn their keep first. I didn't choose em, but I did somehow trick myself into thinking they were actual Toyota wheels. Sheesh.
Did get a good laugh at the term rock DUB.
Spacer will affect your scrub radius turning for sure.
How do they fit?
Does the ctr bore fit over the hubs? (Appear to)
Do the tires stick way out past the flares?
I see 35's so must be lifted. Was wondering if the backspacing will allow you to ditch that 3"(?) spacer for a 1" or none at all.
I'm running a J lift. And it's quite possible that I can go to a smaller spacer or delete it all together, if the offset will allow. There's a lot of room back there. I'll take a better look later when I get done with work. good idea, thanks again.
In the meantime, I might pick up some TEQ branded truck nuts.
Sequoia also have "DUBS" as well, depending on the package.
Those wheels appear pretty flat-faced (technical term), likely you will need at least 1 or 1.5” spacers to prevent them from rubbing the inner sidewalks on the radius arms at full lock to lock turns.
