help me build rear end
I am going to need to run a centered rear end with my new t-case. I was thinking a 66-77 bronco 9" since the wms is 58" and running 31 spline shafts with 4.10's. The FJ40 will see a healthy LT1 700r4 combo and at most 35" tires with moderate wheeling, nothing extreme. Any other ideas, pros cons? i want to keep it as cheap as possible, as my budget is growing thin.
see the last Toyota Trails...excellent article on building your own. Can only get it by joining the TLCA and worth every penny IMO. There are companies that make these but I have heard they are pricey. Try CV Unlimitted in SC if you are looking to buy one premade.
That article rocks. I want to build one just for the hell of it. I just need to find a tcase........
It's not as strong but you could try a Ford 8.8 out of an explorer.
A buddy is running one in his heep cherokee with 4.88's, ARB, disks, and Dutchman alloy shafts with 35" tires. Pretty cheap and sturdy.
No removable 3rd is a downside though...
IMO I would read woody's writeup on centering an LC axle and thing about that.
IIRC the rear end out of a late 70's Lincoln Versailles is the right width too.
I like the idea of running a Ford 9" rear end over a centered cruiser center section.
High pinion is available for Ford 9" as are 35, and 40 spline axles.
Ford 9" bearings, gears, etc etc etc is all ULTRA beefy.
For a ford 9" to Dana 60 comparison see http://www.sunrayengineering.com/nine.html
9" is cool, but for only 35" tires i think the Cruiser center is perfect..
Hi 9"s cost $$$$
no need for 35 or 40 Splines with 35" tires
and The wheel bolt pattern is different
I was looking at a newer ford 1/2 ton the other day, semi floater 10.25 with 6 lug hubs, and I think a few years came with disks optional, how hard could it be to narrow one of these, the axles are probably straight, so you could cut them and have them resplined, for $85 a pair at dutchman, I don't know though, the 8.8 explorer rear seems easier, weld up and redrill the axle flanges.
If you are going to narrow or change the wheel pattern anyway, why not just build the centered cruiser housing? Sounds perfect to me. Even if you don't have a welder, buy the parts, cut and prep and take it to someone else for the welding.
x2
A certain famous Mudder wrote about joining a LC center to minitruck outers - very cool, very economical, very Toyota...
