help ID'ing this weather stripping
Helena MT
Found these on the shelf and can't remember where on the pig they go. I'm thinking tailgate but unsure.
I got these from Lou back in 2008 but only labeled them as 55 rubber.
the "U" shaped one is a few feet long and the other one is 10' long or so.
The "U" shaped one does look like the gasket that holds the rear window to the regulator channel.
If memory serves right, the first is the tailgate and the second is the doors.
The doors one I am sure of because it is a bitch to deal with:mad:
I believe John is right - both pieces are used to put rubber in regulator channel.
The first looks like tailgate, the second looks like door regulator rubber - the flap that hangs down faces out I believe to sheild the regulator metal from water that migrates past the whiskers...
