Help identify these axles
Ontario canada
New to LC's. I bought these believing they were fj40s.... ive had guys on a Facebook group question that these are actually fj60 axles... told me to join this site.... can you help identify these?
the one on the far left still has the center arm attached, it is from a 40 or 55 series both having the same width, if the rest of the axles are the same width then they are 40 or 55 axles.
60 axles are aprox 3 " wider
Look like 40 axles to me. Steering on both from a 40/50. axle vent stock for 40 on both front and rear axles. Brake line routing looks like 40 stuff as well. Locking hubs look like 40 series. Steering arms are also smaller like 40 stuff. 60 and mini truck stuff is bigger.
Check the pinion nuts. 27mm will be course spline pinions, 30mm will be fine spline, 78 only. All look like 76-78 axles.
Ill look into that... question for you... on one of the front axles you can grab the flange and spin the pinion freely, the other front axle when you spin it I believe the front right rotor spins..... what would that mean?
It means the hub is locked on the side with the spinning rotor.
Thanks for the info. So it turns out i have one with 27mm AND one with 30mm. How many spline are each respective pinion? Are there any other differences? And say if I like the coarse spline housing better can i swap the fine spline parts into the other housing? Sorry im an amateur trying to learn as i go...
Keep the fine spline, they are stronger. Yes everything will swap over. Fine spline is ~27 maybe and the course is ~10 I think??? If you use both put the fine spline in the rear, it will take more abuse.
These are going under a samurai so worst case wouldthe coarse spline be ok?
