Help diagnosing front end squeak
Salt Lake City
99 with 200k in it. I've got a front end squeak that's making me crazy. Suddenly appeared a week ago when it got really cold, it's warmed up a little since but the noise decided to stay. Happens when I lift up and down on the front bumper as well as when I turn the steering. I know at 200k there's a myriad of things that probably need to be replaced suspension and steering wise, but before I throw $3k at arm joints, a steering rack, bushings, etc., I'd like to narrow it down. I did the sway bar bushings this morning since I had them and they're easy, didn't solve it.
With it happening during steering that's had me thinking it's probably not the a-arm joints or shocks. I haven't seen any fluid or wetness on the steering rack boots. Any thoughts?
I should have said, steering while stationary, the suspension isn't moving. So that rules out shocks and the arms as the suspension isn't cycling at all. It does it while moving too, if the suspension moves or turning a corner. I'm leaning towards steering rack, just don't know what they sound like then they go and without any fluid leaking I'm not sure. Also checked the PS fluid, it's fine, and it's not groaning like the pump is bad or there's low fluid, it's more like a bushing gone bad type of noise.
I'd suggest having somebody either push on the bumper or turn the steering wheel while you listen from the noise. A transmission rebuilder showed me this trick of using a long screw driver as a "stethoscope". You put the blade on the area you suspect the noise, and your ear on the end of the screw driver (with a plastic handle, rounded end). It works.
If poly steering rack mounting bushings have been installed. They tend to squeak as supplied lube wears thin.
$4 mechanics stethoscope from good ole Harbor Freight says it's most likely a lower ball joint. At least that's what's making the most noise through the stethoscope while I'm under the truck and the wheels are going back and forth. I'll likely get the Autozone/secretly 555 ones and then for a "while you're in there" get tie rods and uppers from @cruiseroutfit since I can see one torn boot on the uppers and at 200k I'm sure the tie rods could be redone as well.
Yeah, the stethoscope is mo bettah. I'd suggest changing the rest, if you have the time.
don' be this guy...
A preview of some good news to come for the 100 series crowd, Cruiser Outfitters @cruiseroutfit will soon be stocking lower AND upper replacement joints from 555. Price looks to be better for all 4 joints than the $160 you'll pay for just the lower two through Autozone/Duralast, which are reboxed 555 joints anyway. In the same shipment he's got 100 series tie rod ends coming too, also be significantly less money than OEM. Kurt said the order is in, they're just waiting for them to show up, probably be end of January when they'll be available. My truck goes in on Tuesday to have them replaced, will report back on how it goes.
Well, quick update. Took it in to the dealership for ball joint replacement. Since Toyota USA doesn't spec out that the ball joints are replaceable, there's no billable labor item for them to go off of. Their best estimate was $950 for the job. Uh, no. Taking it to an independent /Cruiserhead later this week that's doing it for under half that.
^ Yikes... $950 should get you 2 new LCA's with installation.
Guessing a pro could do lower ball joint replacement @ 1-to-1.5hrs per side. Maybe $200-250 total in labor?
Closing this one out in case anyone stumbles upon it searching. Replacing the joints fixed my squeak. Using the stethoscope really helped pinpoint where it was in the front end. If you do try to have a dealership replace the uppers be prepared for sticker shock since it's not a job in their books. The lowers can be done on the truck easily with a c-clamp style ball joint press tool. The uppers have less room to work and the tech wanted to pull them off the truck to use a stand press to do those.
The indy shop, State Automotive, in Midvale, UT, did the whole job for $450. They were awesome to work with and I'll likely be headed back there for my second 90k service. Their initial quote was $550, that included an alignment afterwards, however their rack won't fit on my wheels, but that worked out fine since I have the lifetime Firestone deal anyway.
Truck drives great now, front end feels much tighter, new shocks are definitely a little more bouncy.
Got a question, is it possible for the lower ball joint to squeak but still have zero play on it? I checked for play and it is tight. The boot is in good condition. My squeaks drive side whenever I turn the wheel. I got the same HF scope, and I can definitely hear it on the LBJ and Tie rod. Can't tell which is louder though.
I checked the tie rod for play, and it seems to be fine too.
I've had ball joints squeak with less than half the play of the video above. To me, they sound like the old Dawn 'squeaky clean' commercials.
If they are both original (or of the same age), my money would be on the LBJs before the TREs.
How long did you wait to replace it?
I hate the squeaking and don't tolerate a rubbish ride very well, so I probably replace stuff earlier than most.
If the question is 'how quickly do I need to replace this before it is dangerous', then you can go quite a bit longer. Particularly if you are stressing things by offroading the truck, I am not sure why you would push things longer then you need to. Do it when you have the time/funds and don't stress.
555s are cheap enough, and the DIY takes a while but isn't hard or bank breaking.
