I have an intermittent suspension issue. Sometimes the rear end bottoms out after sitting a while, other times it’s just fine. I couldn’t get the suspension to do it with the key off, but, I did get it to sit on the bumpstops when I put it on the low setting. The bags just kept bleeding and bleeding. Before I go and do a spring swap, what other part should I check. I don’t think the bags are leaking because it’s not an all the time thing. I think maybe its a bleeder valve getting stuck, but I don’t know much about the GX. I have an FSM from the 80, but not this so I don’t know where to turn.
