Picture Courtesy of
@KLF
Wanted to circle back on this. Received the Hewitt Gen II bypass kit and very impressed with quality and packaging. However, I do not have it installed at this point. I have yet to see the code present itself in 5 days so I am waiting to see if this issue presents itself again. I personally do not want to install the bypass kit but will do if this continues to reoccur.
If you are not familiar with this code, it puts you into limp mode immediately (for my 2008 that means no faster than 20-25mph at extremely high revs) and seems to be remedied with a simple unplug of the negative battery cable or do what
@Markuson suggests and put a scan tool, even a cheap one, in your "tool kit" as this takes seconds compared to pulling over, etc.
The main issue from the Tundra sites seems to be failure of the air valves (pictured at the top) which from what you can see requires the intake to be removed in order to replace, or the air pumps themselves of which there are two that sit next to the passenger side wheel well. The hoses pictured above wrap around the front of the engine next to the Oil dip-stick continue down the passenger wheel well by the power steering pump and loop behind the wheel well, connect to the air pumps and from there the ends, or "trumpets", finally stop next to the air filter intake breather hole in the wheel well. There is speculation that the placement of the pumps and trumpets leads to moisture entering the system and over time damaging parts. Replacement of factory parts is rather expensive but what really makes replacing components a no go in my book is reports of the issue returning despite spending the cash. I'm not willing to take that $3-4k gamble.
So the easy solution appears to be the bypass kit and Hewitt Tech does a great job of explaining what the product does along with installation videos and I see nothing but positive reviews and satisfied customers, but for me this is going to be last resort.
This really caught me off-guard when it occurred last week because it came out of nowhere and unlike the water pump, starter, radiator and the other usual preventative maintenance/on going issues that are discussed on this forum constantly, this one was not on my radar at all, and frankly I am surprised its not brought up more frequently based on how common it is on the Tundra.
After doing my due diligence, I decided to go unplug the majority of the the connections from the system, clean the ones easily accessible, and plug back in. I guess this was mostly to make me feel warm and fuzzy inside but I have yet to see the code return. Again, the truck was running perfect, just got done with the 120k maintenance, and had zero indication of any issues.
Food for thought:
Two days before the code presented itself I had the truck inspected at the same shop who inspected it the last two years. No issues before inspection, the truck then passed inspection, and then still no issues after inspection for about 48 hours.
It was unusually humid over the past week and the truck is kept in a garage. It did seem more muggy in the garage than usual when leaving for work last week.
I have no idea if any of that plays a role in this being a fluke but either way the permanent solution is sitting on the shelf, if need be. I'm crossing my fingers that the glitch has been resolved as my scan tool shows all 8 ECU Monitors as "Has Run" and operating normally since Saturday.
Thanks to
@CharlieS and
@jreeder3 for the feedback!
