hellroaring kit install question...
got the hell roading "BC" kit. it is the back up battery switch. i run all my power from the main.
so, one cable goes from the + of the back up battery to A on the BC. Then, one cable goes from A on the BC to the starter solenoid (where it joins the main battery).
Is the stystem that simple? It does not connect directly to the main battery at all?
How does the back up battery stay charged?
Both your main and aux battery will be electrically connected via the starter solenoid connection. That's why in some circumstances you might choose to just go from the pos of the aux battery to the pos of your main.
Yes, the system is simple though I cannot recall the connection details and I'm not sure what you described is correct. Just follow the simple "Backup Battery" wiring diagrams.
When connected as a Backup battery, the system will charge the Backup battery when it detects "Alt good" on the connection from the main battery (basically what would be coming through the cable that is designated for the starter. Most of us with the HR system choose to go from the BIC to the + on the main battery rather than going to the starter because it is easier. Technically this leaves us a little exposed because there could be a failure in the +12v cable to the starter and your backup batter wouldn't start the truck. I'm OK with that risk.
-B-
Instead of connecting at the starter, I connected at the Battery, the instructions say you can do that. I bought a new Terminal that has a longer post bolt to add extra terminals.
As I understand the Hellroaring remote, if it's off, then both batteries will still charge, but they're isolated from each other. Middle is auto, the Hellroaring unit decides how to charge, and on, both batteries connected and charging.
Landtank;
The backup battery is always connected thru the BIC unit. With the REMOTE in the OFF position, automatic combining [placing both batteries in parallel] of the batts is prevented;
OR, from the Hellroaring web site:
After this simple installation of the REMOTE unit, you will now have three Remote positions:
ON - Towards the LED; Combines the backup battery for winching or backup starting, etc...
Automatic - Center Position; Normal operating position for automatic charge and isolation.
OFF - Away from the LED; Disables the automatic function and keeps the batteries Not combined.
The LED mounted in the module will provide an indication of the system status.
I personally can't think of a reason for the OFF position, but maybe someone else can chime in with info on this. You could email Hellroaring and ask them.
I couldn't think of a reason to use the OFF position either. I hooked mine up with a 2-pole switch mounted at the BIC unit. My "OFF" is "Auto" and my "ON" combines the 2 for winching or backup starting.
-B-
Off you could use if your second battery is tanked or not installed, or you have a short or the light starts blinking indicating a bad ground.
I leave it in the auto position.
I probably should add that my eventual plan is to use a rear heater switch customized to add an LED and provide the same functions as the 3-position HR switch. The 2-position switch is a temporary way to hook it up for now.
-B-
Thanks for the understanding. I didn't have time to read all the manual and Pete had done the research and wasn't sure either.
I'd imagine that OFF would be nice if you had a fridge running off of the second battery. That way you could disconnect the 2 batteries during a time of non driving to ensure that the fridge doesn't drain both batteries, just the backup.
Does that sound right?
Kinda, but running anything off the backup battery defeats the purpose. The HR system can be installed a number of different ways. Most of us have selected the "backup battery" mode. What that means is that *nothing* runs off the backup battery. *Everything* is attached to the primary which is recommended to be a deep cycle (e.g. Optima Yellow-top).
This strategy enables you to always have a freshly charged backup battery. If you switch the BIC to "ON" (when wired as BU batt) the 2 batteries will be paralleled for self-jumping or winching. Of course you would want to switch it back to "AUTO" after you finish the winching or whatever needs paralleled batteries.
There are other ways to hook up the HR isolator and I considered doing as you suggested... putting a few things like the fridge & 12v outlets on the "secondary" battery and leaving factory stuff hooked to the "primary" battery. The risk here is that you could run both down. Unlikely, but still possible... say an accessory was left on (door ajar) while camping for 3 days in the bush and using the fridge. If the fishing is good you might forget about charging the batteries and the next thing you know is both got drained. This cannot happen with the "backup battery" strategy. (This all assumes you have good batteries of course.)
My backup battery is an Optima Red-top (starting type battery) and the primary battery is an Optima Yellow-top (deep cycle+starting)
Lotsa ways to skin the cat though. :D
HTH.
-B-
Beowulf said:
My backup battery is an Optima Red-top (starting battery) and the primary battery is an Optima Yellow-top (deep cycle+starting)
HTH.
-B-
thats what i have going on. sounds like connecting at the starter is the way i want to go. rick, looks like you will earn that beer after all!
-Pete
Pete,
You can connect at the starter but it's logically the same point as the + connection on the primary battery. Three of us have already explained this to you but drag that "00" cable down to the starter if it makes you happy... and don't ask Rick do it for you either.
-B-
peepers said:
can i ask rick to supervise and drink all the bass in his fridge?
That is acceptable. Disconnect both grounds before you start.
-B-
Batteries are designed to be exercised (charged and discharged). If you talk to battery engineers, you might find a different opinion with respect to the "always have the backup battery charged, but never use" scheme. Food for thought.
let me preface this by saying i dont understand electrical diagrams...
so, the huge 150amp bussman fuse... i think this goes between the + side of the back up battery and the hollroaring isolator, correct?
and
what do i do with the negative terminal of the back up bettery? what do i ground it to?
thanks!
