hellroaring kit install question...
I installed a large fuse (150amp from HR) between the BIC unit and the main battery. It is best to have the fuse close to the main battery. I chose to put the fuse close to the backup battery and now I am planning to add another close to the main battery.
The backup battery should be grounded to the body and the engine. Use a heavy gauge wire to the block.
Have you read CruiserDrew's install? I think all of this is covered in his installation. There are a couple of others with HR install write-ups so you can get ideas from each.
-B-
-B-
I should clarify....
My install has the big fuse on the +12v side.
Andy and Romer chose to fuse the -12v side.
There are some advantages to fusing the -12v side of the backup battery if you chose to go that route but you need to route the body and engine grounds through the fuse.
I chose the +12v side because I need a +12v terminal to the main battery over on the PS of the vehicle. I already had a HD solenoid and some other wiring in that location so a fuse point made things easier for me.
I may have some pictures ... lemme check .... (Later... OK, found some pics)
The following picture shows the wiring of the BIC. You can also see the 2 pole switch that I selected. It is wired for "Auto" and "On" where "On" combines the 2 batteries and "Auto" isolates the 2 batteries but allows charging of the BU batt.
You should have good covers over all battery connections. A generous 'Mud member sent me these covers for the military terminals.
I plan to add another fuse over on the Main battery side. This would protect the 5' run of 00 gauge wire that runs over to the fuse on the backup battery box.
-B-
There's a threaded boss in the engine block, same as what your other battery is grounded to, but symmetrically on the other side below the manifold. That's where my ground is run, and I used the 150amp fuse on this ground. If you read Cruiserdrew's writeup you'll see he did the same. Also I connected to the starter per the instructions, and wire tied the cable up around the back of the engine to all those other wires up there on the firewall, then up the LH fender. Used every bit of the 8' max. length they give you in the instructions.
One other use for the off position is, if another truck in my group had its battery die I could just give him my second one. Pretty unlikely but you never know, they still let 40's out on runs up here. :)
And I always shove the cables inside some gloves if they're not connected, + a little duct tape. I also have used the second battery to charge the camper battery on the way to camping. Not a reason for the "off switch," but another cool use of this setup... still one of the best mods.
okay Beowulf, so instead of that one that you have marked 12v to main battery, i will be running that to the starter. so, the one 150 amp fuse that i have goes between the BIC and the starter???
Thanks again for helping this electrical idiot >> me.
If you don't have a need for a 12v junction close to the backup battery then fuse the negative side (-12v) like Andy and Ken did in their installs.
-B-
Sorry to but in guys but that looks like a horribly over complex system for something that can be so simple. Can anybody explain to me the advantages of the hellroaring system (I'm not familiar with this system) over other systems.
I have just a basic starter solenoid system on my HZJ80 which works perfectly 24/7 but my HZJ doesn't have any fancy schmancy computer doo hickeys either so they would be unsuitable for you guys but what is wrong with something like the ARB Smart Solenoid (cost/availability?) or other voltage sensitive systems. I've fitted dozens of Smart Solenoids at work with no dramas to HDJ79s and I fit BEP Marine VSR battery management systems to the boats I fit out at work with no dramas.
The HR system is actually quite simple. A little complexity is added by the fuses in mine but I did that for safety. The BIC unit itself couldn't be much simpler; +12v to main battery, +12v to backup battery, & a small ground wire. If that is horribly complex then please elaborate.
The backup battery needs a chasis & block ground. Again, not horribly complex and I'm sure your dual battery system has the same thing, correct?
I added the fuse on the +12v to enable me to have access to the main battery from the PS side of the engine bay. That was my choice; both for safety and for the +12v junction. I have a HD solenoid behind the backup battery (on PS) connects/disconnects power to a 3/4hp air compressor in the rear of the vehicle.
We've discussed pros and cons of various dual battery systems several times in the Outfitting section and a few times here in the 80 section.
The decision on which type of system boils down to: automation, idiot-proof, voltage loss, heat, reliability, ease of install, cost, and probably a couple of others. Each system has advantages and disadvantages. Do some reading and come back with specific questions.
-B-
-B- sorry for that but that photo just looked complex and the talk of a remote switch confused me. I was thinking it was a handheld remote but after rereading it I figured you just meant an aux dash switch. I'm familiar with most of the other systems but just not with the Hellroaring kit.
The remote switch (see yellow & red small wires above) can be located in the dash. It would have another wire to allow switching the backup battery completely out of the system. I suppose you could hold it in your hand .... :D
I chose to mount a 2-pole switch under the bonnet, directly to the bracket for the HR unit. That's the 2 small wires (yellow & red).
The Hellroaring kit is probably very similar to the ARB automatic solenoid. We don't get it here but, IIRC, it is a rebadged "Sure Power" unit. They are physically much larger than the HR unit. The above HR device is a little larger than a deck of playing cards.
-B-
Yeah the Sure Power solenoid is a bit bulky on the top hence why I've changed brands (plus the new ones are slightly cheaper) for the ones I fit at work. The operating principle is the same though.
Do you have any pics of the unit installed so I can see how it is mounted? I can't really see in the photos above.
edit; I just knew if I wrote "above" it would go to the next page. Doh.
Mick;
Here is a pic of how I mounted my HR unit. One of the nice features of this unit is the opacity of the gadget; it will automatically charge both batteries and it is not going to cut into the original wiring of the cruiser. Although I modified my system for future applications, u don't have to.
I originally set my system up with the mechanical / electrical switch and solenoid arrangement and this worked well - one just had to remember to switch in the backup battery for charging etc.
Since I'm a gadget nut, I liked the idea that Hellroaring [Hellroaring, Montana, USA] came up with. They use fast switching MOSFET transistors that have very low forward resistance for low power dissipation. The units can be stacked in parallel for higher current applications.
http://www.hellroaring.com/bic75300.htm
http://homepage.mac.com/dfmorse/BattProj2/page13.html
Thanks for the links dfmorse.
Originally when I saw this unit I didn't like it. But the more I find out about it the more I like it.
I wonder if they are planning on selling them in OZ?
They sell direct so getting them in OZ is possible. When you call, you will likely get directly to the owner. His name is Mike and he is very helpful over the phone. They have been around at least 5 years and their product has evolved over that time.
Their web site needs some work, a LOT of work. IMHO, an enterprising 'Mudder could wget their site, make it pretty, demo it back to Mike, and they could probably make some money.
-B-
For those running items [fridge, 12V inside, whatever] from the aux battery position - what model of Hellroaring isolator are you using? 95300 or 95150?
does anyone have pic of where i can ground on the engine? on the pass side i think someone mentioned a nut? i am going to try to get at this over the weekend.
I'm at work so no picture. The ground I used was near the bottom front of the engine block. Its close to, and I think in front of the motor mount. Anyway, it's a threaded boss that is not being used for anything. I chased out the threads with a tap, cleaned with emery paper and used that to ground my #2 battery.
july of 06 i put the battery tray and battery in the truck...
november of 07 i finally had the nerve, with a little help to hook it up.
the bottom line is i was a bit to worried about it. i followed the directions provided by hellraoring. the 150amp fuse is inline between the BIC and the starter, where they call for it.
there are two 3 amp fuses in line... one on the bid ground and one on the red wire... (i forget where it goes) but its there...
and, we connected the two batteries at the starter even though others have gone + to +.
it works! pics to follow in a bit...
it tested ok from under the bonnet but the LED on the BIC stystem does not light up, nor does the one on the remote control inside the cabin... in any of the 3 positions...
this is how i ran the ground wire (black) from the remote control, through the firewall, through the 3amp fuse to the BIC. i hope i didnt screw things up. damn.
so, do i run a ground wire from the remove and from the BIC itself? ground them both?
