Heavy Shake/Wobble When Braking
Austin, TX
1991 FJ80
So on my way to work yesterday, I felt a wobble and loud noise (sounded like the front of the truck from inside) when I was braking. Then I came to a complete stop and the truck wouldn't move. As we all know power fixes everything so I mashed the gas and it eventually broke free after about 15 yards of grinding. I limped it home for a mile and parked it.
After messing with it last night, I also noticed this only happens in forward but not reverse. Could it be a loose caliper bolt?
Any other ideas? I did the birf rebuild about 1000 miles ago but haven't noticed any issues until today.
There was a thread here a couple of weeks ago that sounded just like what you're describing and it turned out to be a caliper bolt.
Forward but not reverse sounds like a lower caliper bolt somewhere for sure. Id pull both front wheels and inspect asap
Wow. Something in the air. I lost my lower passenger caliper bolt this evening on the freeway. Touched the brake doing 75 and heard a grinding noise. Made my way over to the shoulder and as I came to a stop, the grind went full midevial as the front wheel seized. Put it in reverse and rolled fine. Suspected the caliper, crawled underneath and BINGO, missing lower caliper bolt. Is this an issue? I swear I torqued it when I rebuilt the axle a few months ago.
I have a feeling people are using the German method of torquing those bolts. IIRC it's 75-80ft lbs.
Also another thing I seen with young "professional" shop mechanics is improper use of torque wrenches, improper use of torque adapters. Also when zeroing a torque wrench its Zero on the wrench not 4 turns past it. Another thing is not pulling he s*** out of the wrench to set torque, use a smooth linear pull. A bit OCD, but that's how I was taught. Especially with QA inspectors watching everything you do.
I've been good using a method of going an extra 6-8 ft/lbs on mine, the bolts & hub threads get brake cleaner & blue Loctite (that gel style) - and they are one of few bolts I don't hit with never-sieze / grease.
Lots of threads with guys swearing they hit torque only to loose a bolt within a few weeks. Maybe they're greasing those bolts, IDK.
I lost an upper caliper bolt on the front left side about a month ago. No seizing or anything, but it would flip back and forth depending on the direction you are going. When I did the axles right after, I had to use a 3/4" impact to get the right side bolts off. Left side came off with a ratchet. I bought a new bolt from Toyota for $3-4. I want to say it called to torque them to 90 lbs. I was fortunate that I had no damage.
Thanks for the info guys! That was the issue. Put a new one in and everything seems to be working as designed.
Up north bolts and calipers rust together in short time.
It's the same action that makes brake lines impossible to remove, and rotted out my rockers.
IIRC, you can pull one of the bolts from the tow hooks or the front bumper on the front to use temporarily as a trail fix on the brake calipers.
