Is there a tool that can make the expanded ring at the end of a pipe? If not, is this ring strictly necessary? I see it on all the coolant pipes, but the inlet/outlet pipes to the radiator don't have such a ring and it doesn't leak.
proto1mfg.com
I'm trying to make a heater pipe for my rig. The pipe is discontinued.Yes there is. It’s called a bead roller.
What pipe are you referring to that doesn’t have? I have never seen any OE application pipe without one. You can get by in a pinch as a trail fix but not recommended.
I was mistaken. It's always beaded.I understand, but you said you’ve seen radiator pipes without beads and I’m just curious which specifically you are talking about.
Anything wrong with using aluminum? I was thinking either aluminum or copper.Your using aluminum not brass. Took says aluminum.
Yes there is, they are sized by the pipe diameterIs there a tool that can make the expanded ring at the end of a pipe? If not, is this ring strictly necessary? I see it on all the coolant pipes, but the inlet/outlet pipes to the radiator don't have such a ring and it doesn't leak.
