I searched all over the place to get a definite answer if the Heat Riser GOOD or BAD for the 2F motor and intake manifold. Some claims heat is good, while others saying its bad.
Here are the links.
Man-A-Fre:
When you install headers on an F or 2F equipped Land Cruiser, you lose the stock heat riser, making for longer warm-ups, poor fuel economy, and rough running. With Man-A-Fre's Fluid Heat Riser you not only eliminate the long warm-ups and running problems associated to a cold manifold not properly atomizing the fuel mixture, you also no longer are hitting the bottom of the intake manifold with crack causing exhaust gases. For those of you living in cold climates this is an essential item for proper running with headers. For 1968 through 8/87.
Specter Off-Road:
SOR now offers a replacement stainless steel heat riser for 1/75 to 8/87 intake and exhaust manifold assemblies. This insulator installs between the intake and exhaust manifold. This helps avoid overheating and possible cracking of the intake manifold, a common problem on 2F intake manifolds. This is an important consideration since most of these manifolds are no longer available. Since the insulator for the 1/76 to 7/80 California special is no longer available, we recommend using this insulator. Some heat riser flaps will need minor trimming to fit the Stainless Steel Insulator.
So should one install a Heat Raiser or Block Plate? What will prevent cracking the manifold, warming it up by Heat Raiser or just blocking it off in case of aftermarket exhaust headers.
Here are the links.
Man-A-Fre:
Specter Off-Road:
