Headlight washer/sprayer leaking
Thanks. I went ahead with using RTV, after some thought. What I did was pull the plunger up and stuck a finish nail across to keep it extended an inch or so. Then I *very carefull* put a schmear of RTV down in that groove where the O-ring sits, using a cotton swab. Put it all together, and I'm gonna let it sit overnight like that to make sure the RTV is cured, then put it all back together. If it's still leaking, I'll just get a new one.
The one posted above has a 6 week delivery time now. I also found this one:
Amazon product ASIN B07ZHS73MZ
A little more $$, but it can be here in 3-4 days.
The harness thing is really annoying. I have an idea I'm working on tonight that will hopefully deter them from coming back. Meanwhile the ultrasonic devices are in the trash, the snap traps & peanut butter are coming back out.
Good strategy with the RTV. If it works please post so people have options.
I’ve seen some very clever water-in-bucket traps that can kill lots of mice continuously. If I ever have problems with them where I live it’s gonna be a scorched earth strategy for sure. I’m decent at doing wiring repairs but that doesn’t mean I want to do them.
Hey all, my body colored cap came off - Dog went around the car and leash got underneath it and popped it off. I tried to put it back on but it just shoots off now when I wash. Any idea what the bottom of that body cap/nozzle is supposed to look like? I'm not sure if it is broken or the washer unit.
Did you pull out the inner sprayer assembly against the spring then pop the cap on while it is extended? If not I don’t think the cap will catch the retaining tabs.
My second picture shows the bottom of the cap, and in the small windows you can see the retaining tabs protruding through. I’d give yours a close look and see if any of that isn’t like mine.
Did you try this part? It it a Toyota part like the other one linked that has a longer delivery time?
Yall think I should try the YHTAuto model from amazon that @KLF linked for $55? Or OEM from Partsouq for $117? The one linked on p.1 is a different part number, I guess for an '08.
Same exact issue, drivers side is leaking badly for hours after using them for the first and only time.
Gonna get both sides warrantied i guess to be sure.
Are the part numbers all the same or was this never resolved from T?
Part number was never superceded, that I can find.
And yours has different numbers for the actuators, per my quick look at the diagrams. Seems all years of LX were the same.
Well see if i get to keep my old ones then i will disassemble them and post some photos.
Wondering if they failed in the same spot yours did and what any differences may be if any outside of shape/length or whatever bumper conformity there is.
@bloc
That 10mm bolt seems unreachable. Did you remove or undo anything else to reach it?
Yours looks worse to access than mine, possibly on account of it being pre-facelift.
I do remember needing to have the handle of the wrench pointed toward the other side of the vehicle to be able to actually swing it. I wonder if you do that the open end will grab the top of the bolt head enough to get it moving.
Yeah I'd tried that with a short open ended wrench, but just couldn't get in there. I'll give it another shot.
Dealer wants over $1k to replace everything, parts and labor. So might just try to pinch off the feed line.
Pulling the bumper skin is really not that hard to do on your driveway. That’ll give you full access. Having a helper is a bonus but not required.
Holy old thread batman
While installing my new fog lights I seem to have hit the headlamp washer button which in 2 years I think I’ve used once. A few days later I started noticing a washer fluid leak coming from the drivers front bumper area. Took it back apart today and found it was leaking pretty good from this valve assembly that was a few inches down stream from the washer nozzle. It was covered in foam insulation but once I removed it I confirmed the leak easily.
I used these clamps from HF to cut off the supply, refilled the resi and had the wife blast the washers. No leaks. I can now order the right part and hopefully replace it.
Washer valve was in stock locally for a few bucks. Just replaced it this morning and confirmed leak is secure. The parts diagram on partsouq is very helpful for this one.
