Headlight ?'s
The rating is Water-proof IP65. So for most driving conditions they should be good, but maybe not ideal for total immersion.
I'm more concerned about dirt build-up than actual water. Seems like trail dust combined with water could kill the fans? But I have no personal experience. That was just my though that prevented my purchase.
nuclear out put head lights I was wondering how this effects your driving ability and eye strain at night time while driving in fog and snowy conditions. I want to get some of those high out put lights but do not want to end up in the ditch. Comments please.
I don't have any problems with my HIR's in snow. Yes I turn off the brights. Not much fog in Colorado.
I bought the 9011's on Amazon and they are definitely brighter than OEM bulbs. My question is this, there's two Phillips 9011 bulbs listed on Amazon, a 9011 and a 9011C1. The 9011C1 is listed as being 65W, and some of the reviews says it's a true HIR bulb, leaving me to believe that the other one isn't. I have the 9011's and now I'm wondering if I purchased the wrong ones.
Amazon.com: Philips 9011 HIR Standard Halogen Headlight Bulb (Pack of 1): Automotive
http://www.amazon.com/Philips-9011C1-Light-Bulb/dp/B007XMLPTI/?tag=ihco-20
One is HIR & the other isn't I guess? :meh:
Have any of you mudder installed the Phillips 901C1 bulbs? If so, what's your assessment ?
I am all for depo with retrofit. $300 for depos, $150 for morimoto mini d2s and shrouds, $45 for DDM tuning hids, use or build a hid/hi lo harness or mod a slee harness to work $30. Misc bits and pieces along the way but nothing too spendy.
Order everything, get it all in, remove metal clips around the glass, throw the lights in the oven when the wife isn't looking for 15min, pry them open, bolt in the projector, install and aim projectors, remove and finalize the fitment, throw glass back on and in the oven, remove and throw clips back on and ready install. That's pretty much it in a nut shell. Total time is maybe 2-3 hours if you work slow. There is no cutting/grinding or fabricating anything. It's the most expensive but by far the most rewarding option in terms of headlights.
I myself run depo lights with FXR projectors, 55w ddm hid, custom harness and rigid dually pods in the fog light/high beam position and xb rgb halos.
@shadowless, so the morimoto mini d2 can be put directly into the depos? I have been running a set of depos for 5 years now. Light output is better than oem, but still pretty crappy. Any suggestion on where to buy the morimoto? I'm in Canada.
FWIW, I retro's HIDs into my Wrangler because the headlight options were trash.
I have HIR2 9016 Lows (just have to demel the tabs a bit) on the Slee Harness, perfectly acceptable IMO. If I wanted more output I'd add a set of Rigid D2 SAE fogs, as they can be run legally with the factory lows (I do this on my XJ Cherokee w/ headlight harness), perfectly acceptable as well.
D2 SAE's w/ yellow filter
80-10980765_879625817800_3097759061074530167_n_983bbf861df7797c0528489ae46f77caa2a9c722_zpsxjkz8s6k.jpg
D2 SAE's w/ no filter
80-11001934_879625892650_8127806336771942283_n_7af5d3842d3899ea57d7276df6bd0a7bc4d59a11_zps1hco95sp.jpg
D2 SAE's + Headlights (H4 60W)
80-10364030_879625797840_9000190812838998223_n_1aa99e57f2b649b364e8418ffb3f5f4e4823d9d9.jpg
http://api.***.com/api/click?format=go&jsonp=vglnk_145772497527814&key=88d9c8a0ab3ea24ba6250d4da7f8f93d&libId=ilo3slmr010013qm000DAauwm8yps&loc=http%3A%2F%2Fwww.cherokeeforum.com%2Ff59%2Frigid-industries-d-series-dot-fog-lights-206001%2F&v=1&out=http%3A%2F%2Fcimg3.ibsrv.net%2Fgimg%2Fwww.cherokeeforum.com-vbulletin%2F960x540%2F80-10945031_879625867700_2651155260980715418_n_802c6b26b5f3dc2d4538540a36ddbd104c90a857.jpg&ref=https%3A%2F%2Fwww.google.com%2F&title=Rigid%20Industries%20D-Series%20DOT%20Fog%20Lights%20-%20Jeep%20Cherokee%20Forum&txt=
Everything you need can be found at Theretrofitsource.com to do a projector conversion. Depo lights utilize a h4 bulb, a morimoto mini projector utilizes a h4 alignment shim. Once the h4 bulb reflector is removed from the headlight these can be dropped into the housings and bolted in. Use a straight d2s pig tail if you go with that bulb. And you can buy rubber caps to cover everything behind it like stock. PM me if you have more questions and Ill help as best I can.
Thanks @shadowless I will for sure! Quick question, do the morimoto mini's do low AND high beam? or do you keep the H1 for highs?
They are a bi-xenon. Meaning high and low beam function. The inner lights can become dedicated fog lights. I myself have retrofitted another mini projector in its position for a quad projector conversion. But now have changed over to a rigid dually hyperspot pod light in that spot to stretch light as far as possible while my fxr projectors cover everything in between
My retrofit uses a bi-xenon projector for low/high, and a 100w H1 on the high setting, so lows are projector only, high is the unshrouded projector and H1, throws lots of light!
